    Model disappears when I click Zoom Extents
    4 Posts 2 Posters 3.0k Views 2 Watching
    • P Offline
      PhoebeAnn
      I've had this problem in the past when I had too many Dimension items, but this one has none. If anyone can tell me how to locate the reason for the failure, I'd appreciate it.
      Sheet4c.skp
        This is usually caused by something many miles from the origin causing the model's extents to become unexpectedly large.
        A bug in newer SketchUp versions is known, relating to text associated with geometry...
        When the geometry is deleted its associated text can whizz off into outer-space...
        You can copy+paste this code into the Ruby Console +<enter>
        It moves any such wayward Text entities back to the origin...
        model = Sketchup.active_model
        model.start_operation("TextCheck", false)
        ss = model.selection
        txts = []
        ctr = 0
        puts "\nChecking Text in Model...\n\n"
        model.entities.grep(Sketchup;;Text).each{|t|
          if t.point.to_a.any?(&;nan?)
            ctr+=1
            puts "#{ctr}; \"#{t.text}\" on Layer \"#{t.layer.name}\" @ #{t.point.to_a} - relocated at [0, 0, 0]"
            t.point=ORIGIN
            t.bounds.clear
            t.layer.visible = true
            t.hidden = false
            txts << t
        dtxs = []
        ctr = 0
        puts "\nChecking Text inside Definitions...\n\n"
        model.definitions.each{|d|
          d.entities.grep(Sketchup;;Text).each{|t|
              ctr+=1
              puts "#{ctr}; Defn \"d.name\" ; Text = \"#{t.text}\" on Layer \"#{t.layer.name}\" @ #{t.point.to_a} - relocated at [0, 0, 0]"
              t.point=ORIGIN
              t.bounds.clear
              t.hidden = false
              dtxs << t
          d.invalidate_bounds
        view = model.active_view
        if txts[0]
          model.bounds.clear
          bb = Geom;;BoundingBox.new
          bb.add(ORIGIN)
          model.bounds.add(bb)
          view.refresh
          puts "\nTrying to force Model 'Zoom Extents' - please wait, it might take several seconds..."
          puts "\nThe relocated Model Text will now be Selected - after it completes press Delete if desired..."
          puts "\nAny problem Text relocated inside Definitions must be manually edited..." if dtxs[0]
          ss.clear
          ss.add(txts)
          3.times{
            view.zoom_extents
            view.refresh
          model.commit_operation
          view.refresh
          puts "\nDone."
        elsif dtxs[0]
          puts "\nDone."
          view.refresh
        else
          puts "\nNo Text problems found..."
          model.abort_operation
        puts
        I ran it on your SKP and it's a single Text entity saying, "6 3/4 x 18 24 FV4 GlueLam (B3) above", that is flaky and so far from the origin it's NaN away !
        I haven't attached the fixed SKP, because you can do the simple fix yourself in under a second...
        Also note that your model needs 'fixing' because it has duplicate persistent IDs for several groups [use Model Info > Statistics > Fix...]
        And it'd also be easier to navigate in your model if the Axes were switched on and you used a Perspective Camera...
        • P Offline
          PhoebeAnn
          Thanks. I didn't know I had a Ruby console (using Make 2017), but I'll look. Didn't use perspective camera because I'm working in 2D/parallel all the time. Very likely duplicate IDs - I have never been able to find, use, or delete a group after creating one. You may infer I'm a rank beginner...
          • P Offline
            PhoebeAnn
            Excellent. Thanks again, and thanks for making me do it myself.
