Model disappears when I click Zoom Extents
I've had this problem in the past when I had too many Dimension items, but this one has none. If anyone can tell me how to locate the reason for the failure, I'd appreciate it.
Sheet4c.skp -
This is usually caused by something many miles from the origin causing the model's extents to become unexpectedly large.
A bug in newer SketchUp versions is known, relating to text associated with geometry...
When the geometry is deleted its associated text can whizz off into outer-space...You can copy+paste this code into the Ruby Console +<enter>
It moves any such wayward Text entities back to the origin...model = Sketchup.active_model model.start_operation("TextCheck", false) ss = model.selection txts = [] ctr = 0 puts "\nChecking Text in Model...\n\n" model.entities.grep(Sketchup;;Text).each{|t| if t.point.to_a.any?(&;nan?) ctr+=1 puts "#{ctr}; \"#{t.text}\" on Layer \"#{t.layer.name}\" @ #{t.point.to_a} - relocated at [0, 0, 0]" t.point=ORIGIN t.bounds.clear t.layer.visible = true t.hidden = false txts << t end } dtxs = [] ctr = 0 puts "\nChecking Text inside Definitions...\n\n" model.definitions.each{|d| d.entities.grep(Sketchup;;Text).each{|t| if t.point.to_a.any?(&;nan?) ctr+=1 puts "#{ctr}; Defn \"d.name\" ; Text = \"#{t.text}\" on Layer \"#{t.layer.name}\" @ #{t.point.to_a} - relocated at [0, 0, 0]" t.point=ORIGIN t.bounds.clear t.layer.visible = true t.hidden = false dtxs << t end } d.invalidate_bounds } view = model.active_view if txts[0] model.bounds.clear bb = Geom;;BoundingBox.new bb.add(ORIGIN) model.bounds.add(bb) view.refresh puts "\nTrying to force Model 'Zoom Extents' - please wait, it might take several seconds..." puts "\nThe relocated Model Text will now be Selected - after it completes press Delete if desired..." puts "\nAny problem Text relocated inside Definitions must be manually edited..." if dtxs[0] ss.clear ss.add(txts) 3.times{ view.zoom_extents view.refresh } model.commit_operation view.refresh puts "\nDone." elsif dtxs[0] puts "\nAny problem Text relocated inside Definitions must be manually edited..." puts "\nDone." view.refresh model.commit_operation else puts "\nNo Text problems found..." model.abort_operation end putsI ran it on your SKP and it's a single Text entity saying, "6 3/4 x 18 24 FV4 GlueLam (B3) above", that is flaky and so far from the origin it's NaN away !
I haven't attached the fixed SKP, because you can do the simple fix yourself in under a second...
Also note that your model needs 'fixing' because it has duplicate persistent IDs for several groups [use Model Info > Statistics > Fix...]
And it'd also be easier to navigate in your model if the Axes were switched on and you used a Perspective Camera...
Thanks. I didn't know I had a Ruby console (using Make 2017), but I'll look. Didn't use perspective camera because I'm working in 2D/parallel all the time. Very likely duplicate IDs - I have never been able to find, use, or delete a group after creating one. You may infer I'm a rank beginner...
Excellent. Thanks again, and thanks for making me do it myself.
