    LibFredo6 does not show up under Window menu
    13 Posts 4 Posters 4.9k Views 4 Watching
      resolved
      MacBook Pro mac OS 10.14.6 Mojave
      SketchUp Make 2017
      downloaded LibFredo6_v9.1b.rbz
      install file via Extension Manager
      enabled file
      did not find libFredo6 under Window menu
      quit SketchUp
      restarted SketchUp
      still no libFredo6
      research the internet
      rebooted the computer
      restarted SketchUp
      still no libFredo6
      load other plugins from Fredo
      they all show up in Extension Manager
      but they do not show up in or under any of the menus in SketchUp
      four hours later, other extensions will load but not Fredo products -- any ideas
      • jujuJ Offline
        juju
        libfredo is a supporting (required) library for Fredo's extensions and not an extension in itself
          On its own installing the "LibFredo6" Extension from its RBZ does nothing.
          But it is vital for all of the other Fredo tools, providing each them with shared code, and functionality etc.
          Each of these Fredo tools comes in its own RBZ, each of which need to be installed individually.
          After the installation is done it's recommended that you restart SketchUp to ensure everything gets synced properly.
          Fredo's various tools appear as Extensions listed in the "Extension Manager" and they can be activated/deactivated as needed [note that any extension's deactivation only applies after a restart].
          Note that LibFredo6 must always remain active.
          Its setting can be accessed [if needed] from the Window submenu "LibFredo6 Settings..."
          When active each of Fredo's tools get entries in the Tools submenu items "Fredo Collection" and "Fredo Tools"...
          Many of them also have their own Toolbars [activated from the Palettes menu items on a MAC]...
            resolved
            i know that "libfredo is a supporting (required) library for Fredo's extensions and not an extension in itself" it states that on its website. Knowing that does not solve my problem -- Fredo does not show up in the Window menu or anywhere else.
            "Each of these Fredo tools comes in its own RBZ, each of which need to be installed individually" yes I have downloaded them and installed them and enabled them and they show up in Extension Manager, yet they do not show up under any of the menus in SU
            "Note that LibFredo6 must always remain active.
            When active each of Fredo's tools get entries in the Tools submenu items "Fredo Collection" and "Fredo Tools"..." I have restarted SU many times, I have restart the computer several times, yet "LibFredo6 Settings" does not show up under the Window submenu or anywhere else. They did on my PC, but the HD on my PC bit of dust and it will be another ten days before I get another Dell shipped to me, so I thought I might get some work done on my MacBook Pro
            but LibFridoSettings do NOT show up under any menu so I can not access them the other tools. I have installed another extensions and they work. It is just this one tool that I need that does not show up.
              How did you install LibFredo6?
                Next thought...
                Did you install SketchUp properly ?
                See nearer the end as to why I suspect this...
                Here's how to fix it...
                Whilst logged into Windows as your normal user-account.
                Ensure SketchUp is closed.
                Find the SketchUp installer's exe file - probably in your Downloads folder.
                Select its icon > right-click > context-menu > "Run as administrator"
                When prompted choose "Repair".
                When it completes restart SketchUp and retry...
                [This will NOT affect any customization like your Plugins]
                Installing any complex app in any other way can produce weird unpredictable issues - often around folder/file permissions.
                Double-clicking the installer's exe file to "Run" it is not the same -even if your normal-user has some admin-powers...
                That all said !
                If you installed Fredo's tools and the permissions were badly set up initially, even even Repairing SketchUp might not work, as its preferences set up will not get repaired - because of this you can do the following...
                Close SketchUp.
                Find your Local folder %LocalAppData% and find its subfolder named LIBFREDO6_DATA_Dir - delete it and its contents.
                It is hidden by default, but it should be directly accessible when you use that %...% path in a Windows Explorer window...
                When you restart SketchUp that preferences folder its contents should get recreated, this time with good permissions...
                See if that helps...
                  resolved
                  yes I downloaded three files from Fredo --
                  LibFredo6_v9.1b.rbz
                  Curvizard_v2.4a.rbz
                  Curviloft_v1.8a.rbz
                  yes I installed all three file via Extension Manager, enabled all three, yet there is NO "LibFredo6 Settings" anywhere under any of the menu or submenus
                  yes I have restarted SU many times,
                  yes I have restarted my computer several times
                  yet there is no "LibFredo6 Settings" under any of the menus
                  Fredo worked in my PC "rest in peace" but it will not work in my MacBook Pro
                    resolved
                    thanks so much TIG but my PC died -- I am working on my MacBook Pro
                    I don't have access to those file on the Mac, or better yet I don't know how to get to them, I tried going to "Library" but I could not find anything related to SU but there were a lot of folders and did not go thru them all
                    I went to Applications folder in Finder, moved the SU folder to the Trash, emptied the trash, rebooted the SU dmg reinstalled SU and to my surprise the Extension Manager was as I had left it with all the extension that I have loaded still there, but unfortunately LibFredo6 Settings still did not show up under the Window menu
                    To answer Dave R's question -- install LibFredo6 by clicking on the "Install Extension" button in Extension Manager, selecting the file and clicking on "Open", the file showed up in the Extension Manager I clicked on Enable, quit SU, restarted SU and still no LibFredo6 Settings under the Window menu
                    uninstalling SU, didn't seem to clear the Extension Manager -- how would I do that???
                      Please change your Profile - it says Windows... and in the title !
                      A MAC is quite different.
                      Dave is more MAC-savvy...
                      Hopefully he'll have some ideas...
                      PS:
                      On a MAC the equivalent Fredo Preferences folder is in:
                      " ~/Library/Application Support"
                      and that subfolder is named:
                      " .LIBFREDO6_DATA_Dir"
                      Where the leading '.' makes the folder hidden in unix based systems...
                      However, I wouldn't expect these kinds of permission issues on a MAC...
                        resolved
                        I am so sorry to have wasted your time. It appears that I make a bad assumption.
                        when you play a video on youtube, you click on the triangle to play the video and the triangle is replaced to two parallel lines. when you want to pause the video you click on the pause button and it is replaced with the triangle.
                        I assumed this was true with Extension Manage -- if you want to enable an extension you clicked on Enabled and button switched to Disabled so that you could click on that button to disable the extension. It appears that the "d" makes all the difference. The button shows the status of the extension "Enabled" and clicking on it does the opposite, so I was clicking on "Enabled" thinking I was enabling the extension, whereas I was disabling it. All the difference in a "d" thanks for the help, sorry to have trouble you so
                          resolved
                          thanks TIG I agree it is confusing -- I thought I was getting exact by naming the menu where LibFredo6 was to be found, but instead it is confusing in terms of the OS -- thanks very much for your help
                            So it's solved?
                              resolved
                              yes it is solved
                              sorry my mistake, now I understand the "d" is past tense meaning "status," whereas if it said Enable not "Enabled", that would be present tense meaning "to be done". I over generalized my experience with video buttons and wasted a lot of time. Thanks you Dave R and TIG my apologizes
