    Flextools Windows and Adjacent Pastes
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    6 Posts 4 Posters 11.3k Views 4 Watching
      ArchiJeff
      Greetings! As you can see in the image below inserting my awesome flextools window dyn component works flawlessly as long as it is pasted away from another flextools window. When I paste or insert it directly adjacent to an existing flextools dynamic window it doesn't cut the wall. What am I missing and thanks for your time!
      • jujuJ Offline
        juju
        select the offending DC and press the refresh button
        if you press the refresh button without pre-selecting a DC then all DC's get recalculated
        • halroachH Offline
          halroach
          Hi Jeff,
          Because of current limitations in the wall cutting algorithm, when you try to paste two wall cutting components side by side, in most cases, one of them will not cut an opening (Sometimes it will cut if one of the components is a bit smaller vertically).
          But, we made it so the components can be combined. With a few alterations you can join them together so they look like one, and you can then place them into a new wall cutting component. You can see how that can be done in the following video:
          We have some ideas for future development of more window variations so you wouldn't need to combine windows, and possibly improving the wallcutter algorithm so you could do what you're asking for. Currently though I don't have an exact time frame for that, so combining flex components is the best solution for now.
          I hope that helps.
          FlexTools - Super Quick Windows, Doors, Slats...
            ArchiJeff
            Thank you very much halroach. I appreciate you work and your dedication. I will do as the video indicates and push forward! I look forward more awesomeness from flextools.cc.
            Cheers!
            • halroachH Offline
              halroach
              Cheers!
              You're welcome Sir! Thanks for the kind words 😄
              Yoni
                lukeheth22 Newcomers @halroach
                @halroach
                I'm new to Flex tools and finding the same issue. 6 years on I am just wondering if there is any improved approaches or do I need to follow this one?
                What I am wondering is if there is a way to have adjacent flex windows (critical for my project, many adjacent windows) and maintain the point of the flex tools in being able to adjust the dynamic aspects later. This workflow seems to mean I can no longer adjust the settings the windows individually?
                thanks in advance for any help!
                Luke
