    Animator Problem with Vray Next/Spherical Cam
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    12 Posts 3 Posters 7.5k Views 3 Watching
      changh198
      Hi, i am trying to render object moving animation with VRAY NEXT (Sketchup 2019)
      My VRAY camera is set to VR-Spherical Camera.
      My problem ist that the animator just skips the frame even if it is not done, when the elapsed time of that frame goes over 10:36.
      How can i solve this problem?
      Hooni
      • fredo6F Offline
        fredo6
        There is a time out in Animator for the duration of the generation of each frame. I could of course increase the timeout value, but 10 minutes is already a lot.
        I would suggest that you tweak the VRAY parameters to get the generation of each frame to be much faster, even if you lose a little bit of quality. In an animation, this is usually acceptable.
          changh198
          how can i increase the timeout value? im rendering with for my VR with Stereo-Option for Camera on. So i kinda need that quality.
          it would be great actually if there is no timeout at all!
          thx for quick answer!
          • fredo6F Offline
            fredo6
            I have increased the timer to 60 minutes instead of 10 minutes. I hope this will be enough.
            Please install LibFredo6 v9.1b.
            Fredo
              changh198
              Thankyou!
                changh198
                Fredo
                Now i deleted the version i installed tried to install new one, but i cant get installed on the extension manager of skup somehow...
                  changh198
                  Fredo
                  can you make it 120min pls? it would be great!
                    changh198
                    Fredo
                    sorry i installed it!
                    last question would be if its possible to have the timeout more than 60?
                    i wann have really high resoultion with vray and for that i need actually half a day to render a frame
                    and if you render over animator with vray, vray swarm doesnt work. is there any way to make vray swarm work with animator?
                    • fredo6F Offline
                      fredo6
                      OK. I'll make it configurable in the next release.
                      I hope this will work for you.
                      Fredo
                        rv1974
                        Fredo
                        Are you seriously going to invest 75 days for say 1 min animation (15 FPS)? πŸ˜†
                          changh198
                          Fredo
                          It takes not that long
                          a little πŸ˜‰
                          but result is impressive with vr πŸ˜„
                            rv1974
                            I guess throwing the model to UE and evenlearning it from zero would take considerably less time
