    Silent Sentinels
    18 Posts 6 Posters 2.9k Views 6 Watching
    • tuna1957T Offline
      tuna1957
      Some more of my foolishness. Played around with this one off and on for quite a while. Never did get the rock looking just like I'd hoped. Oh well... still turned out pretty good me thinks. Do you want to shout at the one explorer "Don't go around the corner" πŸ˜† . Raw SU view and a render. Rendered with Twilight, post pro Affinity. Cheers πŸ‘
      • pbacotP Offline
        Very cool! Reminds me of the Toltec warriors and Arthur C. Clarke. Like the colors too.
        http://2.bp.blogspot.com/-qK73giltqME/UxcsaoV6goI/AAAAAAAAHW0/z4qQF604iq0/s1600/IMGP5064.JPG
          These moody renders are marvelous,I could easily see them as the basis for a sci-fi comic series.
          • cheddaC Offline
            chedda
            I like the concept, did you erode the tunnel walls they look good but maybe more deflections ?
            Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
            • tuna1957T Offline
              tuna1957
              Thanks everyone πŸ‘ .
              Chedda , The walls have some irregularity to them , I used Vertex Tools move function. Had the "soft select" set to about 3'. Just random "bumps and depressions" down the sides. I tried Enroth's Erode , let it run over two hours no
              result , got impatient and force quit and used Vertex Tools. Plan to mess about some more trying some different textures.
              • cheddaC Offline
                chedda
                I'd use a really low poly tube say 12 sided on a 12 part arc then run erode. I might then run divide and smooth too. You have inspired me for a sea cave scene, watch this space πŸ˜‰
                • Bryan KB Offline
                  Very cool!
                  • tuna1957T Offline
                    tuna1957
                    Thanks Bryan.
                    couldn't help myself ... tweaked the model some and ran a new render.....
                    • ntxdaveN Offline
                      ntxdave
                      I am curious about the texture you use for the floor. I like it but have not been able to achieve the same affect for my floor. I "see" yours with a little roughness (which is what I would like to have with a lite gray color).
                      Press F1...thank me later
                      • tuna1957T Offline
                        tuna1957
                        ntxdave , The floors a "concrete floor" texture I got from the Textures.com site. Made a bump and reflective map in Gimp. The bumps set fairly low for this render.
                        • ntxdaveN Offline
                          ntxdave
                          Thanks Tuna. Guess I need to learn how to do that. I do not have Gimp and have never created a bump. Know of any good tutorials for me to learn from?
                          • tuna1957T Offline
                            tuna1957
                            ntxdave , If you dig around in the "tips and tricks" section on the Twilight forum there are some posts about creating bump and reflection/specular maps.
                            Also if your just using a solid color for your floor have you tried using a seamless "noise" map to get a little texture to the floor ?
                            • ntxdaveN Offline
                              ntxdave
                              Educate me. What is a noise map?
                              • tuna1957T Offline
                                tuna1957
                                ntxdave , A noise map is used like a bump map but it's not created from a particular texture image that has been used in the model. You load it in the bump slot in Twilights material editor. It will give a random "roughness" to the surface of the texture your using it with.
                                Examples would be a solid color that is painted to the walls or ground surface in a model. Using one will give a roughness to the surface and lend a more realistic look to a render.
                                Sending you a p.m.
                                • ntxdaveN Offline
                                  ntxdave
                                  Tuna, is this where I should be applying the Noise Map?
                                  Noise Map Setting
                                  • pbacotP Offline
                                    Great picture! Thanks for sharing, and giving ideas about rendering.
                                    One idea: having been watching some space shows lately...I'd like to see both explorers lit up a little more with more lively action suggested from headlamps, flashlights or tricoders, maybe some indicator lights on the suits. They are the active characters in the shot while the rest is silent and mysterious by contrast.
                                    • tuna1957T Offline
                                      tuna1957
                                      pbacot , Thanks . Your comments - suggestions are always welcomed. I'm kind of real old school in my taste for ski-fi. Think it sort of reflects in how I set these type of models up..... that said for me the star of this crazy show is the "sentinel" , to me the "astro-nuts sort of take a back seat..... πŸ˜‰
                                      • Bryan KB Offline
                                        That 2nd render really "pops".
