    Problem with DXF export in 2019
    13 Posts 2 Posters 1.9k Views 2 Watching
    • bazB Offline
      baz
      I have successfully exported non-segmented arcs to DXF for CNC work many times in the past. But now, in 2019 she no work.
      This is the method I have always used:
      Set view to Top.
      Set camera to Parallel projection.
      Delete faces leaving only lines.
      Export 3D Model as DXF, ACad 14.
      Also tried exporting from LO, same result.
      Anyone else seeing this?
      Steps-CNC.dxf
      Steps-CNC.skp
        Curious. I see it too. Not what I would have expected.
        • bazB Offline
          baz
          Glad it's not just me. I will try redrawing from scratch.
            Instead of redrawing them in SketchUp, maybe you could trace them in LayOut and erase the viewport before exporting.
            • bazB Offline
              baz
              Dave, I had already redrawn before your trace suggestion.
              But curiously, even though I now have smooth arcs they fail to join up in the DXF.
              However the SU model had no gaps and perfectly closed faces...
              I'm stumped...
              SU Closed faces
              DXF in Layout
              (/uploads/imported_attachments/jepy_Steps-CNC_2.dxf)
              Steps-CNC_2.skp
                Did you draw the lines shown in the second screenshot with LayOut's tool? Did you have Grid Snapping enabled?
                • bazB Offline
                  baz
                  No, second shot is a DXF export from SU, only opened in Layout. Also checked it in the Autocad online viewer.
                  Cheers
                    Oh. I see. Hmmm.... I don't know why that break should be there. I didn't see it on this end when I was playing with your previous file. I haven't looked at this latest one because I'm on my phone.
                    Did you try drawing the curves in LayOut with LayOut's tools?
                    d
                    • bazB Offline
                      baz
                      The break didnt appear in the previous file with the segmented curves. Only in the second iteration with proper arcs. I don't have any experience drawing in LO. Only ever use it for dimensions and presentation.
                      I am finding a few other things with this latest release, hardly enough to notice, but things not acting as they used to. One example: Cant get the start of a line, circle etc to infer to a construction point in Top view, but orbit the view a little and bingo.
                        LayOut's drawing tools work very much like those in SketchUp. Use Scaled Drawing, select the appropriate scale and then you can enter real world dimensions as you would in SketchUp. Curves in LayOut are smooth and not segmented as in SketchUp.
                        I haven't seen any issues with inferencing in Plan view. I'll have to look when I get back to my computer.
                        • bazB Offline
                          baz
                          Maybe I should re-install. Will look at it tomorrow, got to watch GOT then bed πŸ˜„
                            Don't know that reinstalling SketchUp will help but probably won't hurt. Make sure you right click on the installer and choose Run as administrator if you do reinstall. Then pick the Repair option.
                            Enjoy your GOT and sleep. I've never seen the former and only see the latter once in awhile. πŸ˜‰
                            • bazB Offline
                              baz
                              πŸ˜„
                              Ok, traced in LO and got a good result. Have to consider this a workaround tho'. And a bit of a pain as easy to miss endpoints in LO. (No option to toggle endpoints)
                              Thanks for the help Dave.
                              Cheers.
