    Open 2017 skp in sketchup 2016 (plugin?)
    6 Posts 4 Posters 6.2k Views 4 Watching
      joiner
      hell0
      sory for my bad english
      is there a plugin (or annything)to convert skp 2017 to skp 2016 (to open it
      with sketchup 2016)
      thanks
      joiner
      • HornOxxH Offline
        HornOxx
        Hi - Yes it is !! πŸ˜„
        Julia Christina Eneroth wrote this Plugin:
        https://extensions.sketchup.com/en/content/eneroth-open-newer-version
        instead of just opening any skp-file, this cool plugin creates a copy in your desired version first, next to the original file. (your profile still shows SkUp 2013 Pro but you have SkUp 2016?)
        never trust a skinny cook
          As well as Eneroth's extension the general solution is this... if you or the SKP's author still has v2017 installed then you can do a 'Save_As' and choose an earlier SketchUp version from the drop-down list of versions: then the saved SKP is say v2016 and usable in all versions from v2016 upwards...
          • HornOxxH Offline
            HornOxx
            ...which furthermore also is a good practice for sharing files here if necessary for any reasons πŸ˜‰
            • hdpvH Offline
              hdpv
              Try my program
              https://sketchucation.com/forums/viewtopic.php?f=323&t=70710
              Support Sketchup 2019.
              Suforyou
              http://www.sketchupforyou.com
                joiner
                Hello
                That's i need. πŸ‘
                Thanks to all. πŸ˜„ πŸ˜„
                joiner
