    Generation of Video Problem
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    10 Posts 5 Posters 9.9k Views 5 Watching
    • B
      berezen
      Hello Fredo6!
      Big Thank`s for your work and this amazing plugin
      I have made made a mistake when setting up a plugin to generate video...I choose incorrect files when program asking me for "How to get FFMpeg"
      (ScreenShot001)
      after my mistake I have this:
      (ScreenShot002) Looks correct, but it is not working. Error in the end of Generating
      Now I understand how to make correct, I download right plugins (from here: http://ffmpeg.org/download.html)
      BUT: I don`t know how to clear old incorrect plugins for Generate Video. How I can turn to situation in ScreenShot001?
      (Deleting folders Fredo6 in plugins - didn`t work)
      Really need Your Help!
      ScreenShot001
      ScreenShot002
      • fredo6F
        fredo6
        Just delete the old, invalid ffmpeg.exe and you should be back to the situation where Animator will ask you the location.
        • B
          berezen
          Can`t find it
          Can you tell exactly where to look? Which folder?
          • fredo6F
            fredo6
            @berezen said:
            Can`t find it
            This is the place where you originally set the location of FFmpeg.exe
            Open the Ruby Console and type
            Traductor::FFmpeg.new.program_locate
            I think I'll make a permanent command to change the setting of the location of FFmpeg. That will be easier when correcting mistakes.
            • A
              alvin meza
              como resolviste tengo el mismo problema descargo el archivo y copio lo que dice en la consola pero aun asi no me sale....
              • L
                Luigi62
                @fredo6 said:
                @berezen said:
                Can`t find it
                Hi Fredo,
                I have the same problem as Berezen. While waiting for the update with a permanent command to change the setting of the location of FFmpeg, is it possible to have a detailed explanation in order to return to the original window asking "How to get FFMpeg" (by manually editing a file, for example)?
                • fredo6F
                  fredo6
                  I have added a permament button in version 2.4d.
                  • L
                    Luigi62
                    @fredo6 said:
                    [attachment=0:2h6evhub]<!-- ia0 -->FFmpeg button reload.png<!-- ia0 -->[/attachment:2h6evhub]
                    Thanks a lot for your job !
                    • M
                      MKO
                      Pls a Fredo pop up is saying the animator 2.4d as expired. I tried updating through the link displayed but it won't pls what can I do?
                      • fredo6F
                        fredo6
                        Unless you changed the clock on your PC, Animator v2.4d is valid till 14 Sep 19.
                        Fredo
