    Reading numbers from external text file
    18 Posts 2 Posters 8.6k Views 2 Watching
    • PixeroP
      Pixero
      Can someone shed some light on how to read from an external text file and finding the relevant data?
      I have a txt file that originally is a json file and has some stuff that is not needed to read so how do I find the parts I want to read?
      Can you tell the script to read from certain lines?
      How do you cope with lines like these?
            "x"; -0.6789975732998361,
            "y"; 0.0008515437495198585
      If I know that for example line 66 will always be this: "x": (and some float) -0.6789975732998361, how do I skip the:
      "x";
      and the final comma?
      • TIGT
        If it has a space after the : and you want the answer as a float number, then use:
        value = string.split(' ')[1].to_f - ignores any commas at end of string, it makes into a float
        OR if unsure, but there's always a : use:
        value = string.split(':')[1].lstrip.to_f
        To read ALL of the lines in a file use:
        lines = IO.readlines(file)
        If you definitely always want line 66
        string = lines[65]
        OR find it by its variable, there are many ways - e.g.
        string = ''
        lines.each{|line|
          if line.lstrip =~ /["]x["][;]/ ### strip off leading white-space & starts "x";
            string = line
            break ### take first match
        • PixeroP
          Pixero
          Thanks. Ill try with this.
          • PixeroP
            Pixero
            Next question.
            This is the code I'm experimenting with:
            @settings = []
            def load_file(file_path, status)
              @filepath = UI.openpanel("Open File", "c;/", "TXT|*.txt||")
              @settings = File.readlines(@filepath)
              return 0   # Success
            load_file(@filepath, true)
            puts @settings[2].split(' ')[1].to_f
            After loading the file I managed to get the number as a float but after running this I also get a:
            3.4919929866069115 #This is a number I want to read. So this is fine.
            "Nil result (no result returned or run failed)" #Why do I get this?
            • TIGT
              You don't need to return anything from the method.
              So delete the unneeded line.
              return 0 # Success
              You haven't posted all of your code, so it could be something elsewhere ?
              A simpler version would be...
              @settings = []
              def load_file()
                if filepath ### allows a user to Cancel
                  @settings = File.readlines(filepath)
              load_file()
              ### to see what @settings looks like use;
              p @settings
              ### This will show spacers, \", \n etc
              • PixeroP
                Pixero
                Thanks, but I still get the Nil result even after removing the "Return 0".
                I even get it when running your code.
                For now I'm just experimenting with this part so there is no other code.
                The line I'm testing with looks like this:
                    "x"; 3.4919929866069115,
                • TIGT
                  Did you use the whole code with p @settings at the end ?
                  What do the first few lines of its output look like ?
                  Also adding: puts @settings[2].split(' ')
                  and puts @settings[2].split(' ')[1] to see what's up...
                  • PixeroP
                    Pixero
                    ["{\n", "  \"principalPoint\"; {\n", "    \"x\"; 3.4919929866069115,\n", "    \"y\"; -0.017301744356540385\n", "  },\n", "  \"viewTransform\"; {\n", "    \"rows\"; [\n", "      [\n", "        -0.9075910551963806,\n", "        0.4198243379864999,\n", "        -0.005099192261283809,\n", "        -31.940051338855746\n", "      ],\n", "      [\n", "        0.00419330408856825,\n", "        -0.003080616899800699,\n", "        -0.9999864629085424,\n", "        -0.10391287329462531\n", "      ],\n", "      [\n", "        -0.4198343634438959,\n", "        -0.9076001515170179,\n", "        0.0010354892297866703,\n", "        -17.250974969132418\n", "      ],\n", "      [\n", "        0,\n", "        0,\n", "        0,\n", "        1\n", "      ]\n", "    ]\n", "  },\n", "  \"cameraTransform\"; {\n", "    \"rows\"; [\n", "      [\n", "        -0.9075910551963807,\n", "        0.00419330408856825,\n", "        -0.41983436344389585,\n", "        -36.23062125433451\n", "      ],\n", "      [\n", "        0.41982433798650004,\n", "        -0.0030806168998006997,\n", "        -0.9076001515170179,\n", "        -2.2480967029645083\n", "      ],\n", "      [\n", "        -0.005099192261283809,\n", "        -0.9999864629085424,\n", "        0.0010354892297866703,\n", "        -0.24891673044480064\n", "      ],\n", "      [\n", "        0,\n", "        0,\n", "        0,\n", "        1\n", "      ]\n", "    ]\n", "  },\n", "  \"horizontalFieldOfView\"; 0.9813963064459168,\n", "  \"verticalFieldOfView\"; 0.6616350540688956,\n", "  \"vanishingPoints\"; [\n", "    {\n", "      \"x\"; -0.5541295463355106,\n", "      \"y\"; 0.0013923823242965234\n", "    },\n", "    {\n", "      \"x\"; 4.357757655415969,\n", "      \"y\"; -0.02365461394665286\n", "    },\n", "    {\n", "      \"x\"; 12.708844850226638,\n", "      \"y\"; 1807.4703594352652\n", "    }\n", "  ],\n", "  \"vanishingPointAxes\"; [\n", "    \"xPositive\",\n", "    \"yPositive\",\n", "    \"zPositive\"\n", "  ],\n", "  \"relativeFocalLength\"; 1.8716593429474995,\n", "  \"imageWidth\"; 5000,\n", "  \"imageHeight\"; 3214\n", "}"]
                    "[\"{\\n\", \"  \\\"principalPoint\\\"; {\\n\", \"    \\\"x\\\"; 3.4919929866069115,\\n\", \"    \\\"y\\\"; -0.017301744356540385\\n\", \"  },\\n\", \"  \\\"viewTransform\\\"; {\\n\", \"    \\\"rows\\\"; [\\n\", \"      [\\n\", \"        -0.9075910551963806,\\n\", \"        0.4198243379864999,\\n\", \"        -0.005099192261283809,\\n\", \"        -31.940051338855746\\n\", \"      ],\\n\", \"      [\\n\", \"        0.00419330408856825,\\n\", \"        -0.003080616899800699,\\n\", \"        -0.9999864629085424,\\n\", \"        -0.10391287329462531\\n\", \"      ],\\n\", \"      [\\n\", \"        -0.4198343634438959,\\n\", \"        -0.9076001515170179,\\n\", \"        0.0010354892297866703,\\n\", \"        -17.250974969132418\\n\", \"      ],\\n\", \"      [\\n\", \"        0,\\n\", \"        0,\\n\", \"        0,\\n\", \"        1\\n\", \"      ]\\n\", \"    ]\\n\", \"  },\\n\", \"  \\\"cameraTransform\\\"; {\\n\", \"    \\\"rows\\\"; [\\n\", \"      [\\n\", \"        -0.9075910551963807,\\n\", \"        0.00419330408856825,\\n\", \"        -0.41983436344389585,\\n\", \"        -36.23062125433451\\n\", \"      ],\\n\", \"      [\\n\", \"        0.41982433798650004,\\n\", \"        -0.0030806168998006997,\\n\", \"        -0.9076001515170179,\\n\", \"        -2.2480967029645083\\n\", \"      ],\\n\", \"      [\\n\", \"        -0.005099192261283809,\\n\", \"        -0.9999864629085424,\\n\", \"        0.0010354892297866703,\\n\", \"        -0.24891673044480064\\n\", \"      ],\\n\", \"      [\\n\", \"        0,\\n\", \"        0,\\n\", \"        0,\\n\", \"        1\\n\", \"      ]\\n\", \"    ]\\n\", \"  },\\n\", \"  \\\"horizontalFieldOfView\\\"; 0.9813963064459168,\\n\", \"  \\\"verticalFieldOfView\\\"; 0.6616350540688956,\\n\", \"  \\\"vanishingPoints\\\"; [\\n\", \"    {\\n\", \"      \\\"x\\\"; -0.5541295463355106,\\n\", \"      \\\"y\\\"; 0.0013923823242965234\\n\", \"    },\\n\", \"    {\\n\", \"      \\\"x\\\"; 4.357757655415969,\\n\", \"      \\\"y\\\"; -0.02365461394665286\\n\", \"    },\\n\", \"    {\\n\", \"      \\\"x\\\"; 12.708844850226638,\\n\", \"      \\\"y\\\"; 1807.4703594352652\\n\", \"    }\\n\", \"  ],\\n\", \"  \\\"vanishingPointAxes\\\"; [\\n\", \"    \\\"xPositive\\\",\\n\", \"    \\\"yPositive\\\",\\n\", \"    \\\"zPositive\\\"\\n\", \"  ],\\n\", \"  \\\"relativeFocalLength\\\"; 1.8716593429474995,\\n\", \"  \\\"imageWidth\\\"; 5000,\\n\", \"  \\\"imageHeight\\\"; 3214\\n\", \"}\"]"
                    • PixeroP
                      Pixero
                      3.4919929866069115
                      "x";
                      3.4919929866069115,
                      • PixeroP
                        Pixero
                        3.4919929866069115
                        3.4919929866069115,
                        • PixeroP
                          Pixero
                          Here is the txt file I'm loading. (It's a json file from the beginning.)
                          test1.txt
                          • TIGT
                            Are you running this in the Ruby Console, or in some other console extension ?
                            Try this without the ' def'
                            filepath = UI.openpanel("Open File", "C;/", "TXT|*.txt||")
                            if filepath ### allows user to Cancel
                              puts settings[2].split(' ')[1].to_f
                            else
                              puts "Canceled!"
                            • TIGT
                              Our posts crossed.
                              Both my versions of the code work fine with your TXT file, with no error [in Ruby Console].
                              So do you use a console-app ?
                              • PixeroP
                                Pixero
                                Interesting.
                                Running your latest code in the console works but running it in SketchUp Ruby Code Editor by Alexander Schreyer gives the Nil result also.
                                I also tried your first version in the console and it worked without errors.
                                So is it safe to continue if it's just something in his Code editor app that causes the Nil result?
                                • TIGT
                                  Most of these console-apps are not perfect...
                                  I only ever use the Ruby Console.
                                  • PixeroP
                                    Pixero
                                    Thanks for all the help so far. I'm sure there will be more later on...
                                    If only the Ruby console was multi lines. It's hard to edit in the small window.
                                    • TIGT
                                      I always edit my code in a Notepad++/TextWrangler window [with Ruby text-highlighting], then I copy/paste it into the Ruby Console's bottom bar + enter, to run it.
                                      The Ruby Console accepts multi-line code if pasted, but you can only manually type in one line at a time!
                                      • PixeroP
                                        Pixero
                                        I use Notepad++ as well but use the ruby code editor when testing out snippets without having to restart SketchUp.
                                        Now I’ll continue with the main work.
