    Reading numbers from external text file
    18 Posts 2 Posters 8.7k Views 2 Watching
      Did you use the whole code with p @settings at the end ?
      What do the first few lines of its output look like ?
      Also adding: puts @settings[2].split(' ')
      and puts @settings[2].split(' ')[1] to see what's up...
      • PixeroP
        Pixero
        ["{\n", "  \"principalPoint\"; {\n", "    \"x\"; 3.4919929866069115,\n", "    \"y\"; -0.017301744356540385\n", "  },\n", "  \"viewTransform\"; {\n", "    \"rows\"; [\n", "      [\n", "        -0.9075910551963806,\n", "        0.4198243379864999,\n", "        -0.005099192261283809,\n", "        -31.940051338855746\n", "      ],\n", "      [\n", "        0.00419330408856825,\n", "        -0.003080616899800699,\n", "        -0.9999864629085424,\n", "        -0.10391287329462531\n", "      ],\n", "      [\n", "        -0.4198343634438959,\n", "        -0.9076001515170179,\n", "        0.0010354892297866703,\n", "        -17.250974969132418\n", "      ],\n", "      [\n", "        0,\n", "        0,\n", "        0,\n", "        1\n", "      ]\n", "    ]\n", "  },\n", "  \"cameraTransform\"; {\n", "    \"rows\"; [\n", "      [\n", "        -0.9075910551963807,\n", "        0.00419330408856825,\n", "        -0.41983436344389585,\n", "        -36.23062125433451\n", "      ],\n", "      [\n", "        0.41982433798650004,\n", "        -0.0030806168998006997,\n", "        -0.9076001515170179,\n", "        -2.2480967029645083\n", "      ],\n", "      [\n", "        -0.005099192261283809,\n", "        -0.9999864629085424,\n", "        0.0010354892297866703,\n", "        -0.24891673044480064\n", "      ],\n", "      [\n", "        0,\n", "        0,\n", "        0,\n", "        1\n", "      ]\n", "    ]\n", "  },\n", "  \"horizontalFieldOfView\"; 0.9813963064459168,\n", "  \"verticalFieldOfView\"; 0.6616350540688956,\n", "  \"vanishingPoints\"; [\n", "    {\n", "      \"x\"; -0.5541295463355106,\n", "      \"y\"; 0.0013923823242965234\n", "    },\n", "    {\n", "      \"x\"; 4.357757655415969,\n", "      \"y\"; -0.02365461394665286\n", "    },\n", "    {\n", "      \"x\"; 12.708844850226638,\n", "      \"y\"; 1807.4703594352652\n", "    }\n", "  ],\n", "  \"vanishingPointAxes\"; [\n", "    \"xPositive\",\n", "    \"yPositive\",\n", "    \"zPositive\"\n", "  ],\n", "  \"relativeFocalLength\"; 1.8716593429474995,\n", "  \"imageWidth\"; 5000,\n", "  \"imageHeight\"; 3214\n", "}"]
        "[\"{\\n\", \"  \\\"principalPoint\\\"; {\\n\", \"    \\\"x\\\"; 3.4919929866069115,\\n\", \"    \\\"y\\\"; -0.017301744356540385\\n\", \"  },\\n\", \"  \\\"viewTransform\\\"; {\\n\", \"    \\\"rows\\\"; [\\n\", \"      [\\n\", \"        -0.9075910551963806,\\n\", \"        0.4198243379864999,\\n\", \"        -0.005099192261283809,\\n\", \"        -31.940051338855746\\n\", \"      ],\\n\", \"      [\\n\", \"        0.00419330408856825,\\n\", \"        -0.003080616899800699,\\n\", \"        -0.9999864629085424,\\n\", \"        -0.10391287329462531\\n\", \"      ],\\n\", \"      [\\n\", \"        -0.4198343634438959,\\n\", \"        -0.9076001515170179,\\n\", \"        0.0010354892297866703,\\n\", \"        -17.250974969132418\\n\", \"      ],\\n\", \"      [\\n\", \"        0,\\n\", \"        0,\\n\", \"        0,\\n\", \"        1\\n\", \"      ]\\n\", \"    ]\\n\", \"  },\\n\", \"  \\\"cameraTransform\\\"; {\\n\", \"    \\\"rows\\\"; [\\n\", \"      [\\n\", \"        -0.9075910551963807,\\n\", \"        0.00419330408856825,\\n\", \"        -0.41983436344389585,\\n\", \"        -36.23062125433451\\n\", \"      ],\\n\", \"      [\\n\", \"        0.41982433798650004,\\n\", \"        -0.0030806168998006997,\\n\", \"        -0.9076001515170179,\\n\", \"        -2.2480967029645083\\n\", \"      ],\\n\", \"      [\\n\", \"        -0.005099192261283809,\\n\", \"        -0.9999864629085424,\\n\", \"        0.0010354892297866703,\\n\", \"        -0.24891673044480064\\n\", \"      ],\\n\", \"      [\\n\", \"        0,\\n\", \"        0,\\n\", \"        0,\\n\", \"        1\\n\", \"      ]\\n\", \"    ]\\n\", \"  },\\n\", \"  \\\"horizontalFieldOfView\\\"; 0.9813963064459168,\\n\", \"  \\\"verticalFieldOfView\\\"; 0.6616350540688956,\\n\", \"  \\\"vanishingPoints\\\"; [\\n\", \"    {\\n\", \"      \\\"x\\\"; -0.5541295463355106,\\n\", \"      \\\"y\\\"; 0.0013923823242965234\\n\", \"    },\\n\", \"    {\\n\", \"      \\\"x\\\"; 4.357757655415969,\\n\", \"      \\\"y\\\"; -0.02365461394665286\\n\", \"    },\\n\", \"    {\\n\", \"      \\\"x\\\"; 12.708844850226638,\\n\", \"      \\\"y\\\"; 1807.4703594352652\\n\", \"    }\\n\", \"  ],\\n\", \"  \\\"vanishingPointAxes\\\"; [\\n\", \"    \\\"xPositive\\\",\\n\", \"    \\\"yPositive\\\",\\n\", \"    \\\"zPositive\\\"\\n\", \"  ],\\n\", \"  \\\"relativeFocalLength\\\"; 1.8716593429474995,\\n\", \"  \\\"imageWidth\\\"; 5000,\\n\", \"  \\\"imageHeight\\\"; 3214\\n\", \"}\"]"
        • PixeroP
          Pixero
          3.4919929866069115
          "x";
          3.4919929866069115,
          "Nil result (no result returned or run failed)"
          • PixeroP
            Pixero
            3.4919929866069115
            3.4919929866069115,
            • PixeroP
              Pixero
              Here is the txt file I'm loading. (It's a json file from the beginning.)
              test1.txt
                Are you running this in the Ruby Console, or in some other console extension ?
                Try this without the ' def'
                filepath = UI.openpanel("Open File", "C;/", "TXT|*.txt||")
                if filepath ### allows user to Cancel
                  settings = File.readlines(filepath)
                  puts settings[2].split(' ')[1].to_f
                else
                  puts "Canceled!"
                  Our posts crossed.
                  Both my versions of the code work fine with your TXT file, with no error [in Ruby Console].
                  So do you use a console-app ?
                  • PixeroP
                    Pixero
                    Interesting.
                    Running your latest code in the console works but running it in SketchUp Ruby Code Editor by Alexander Schreyer gives the Nil result also.
                    I also tried your first version in the console and it worked without errors.
                    So is it safe to continue if it's just something in his Code editor app that causes the Nil result?
                      Most of these console-apps are not perfect...
                      I only ever use the Ruby Console.
                      • PixeroP
                        Pixero
                        Thanks for all the help so far. I'm sure there will be more later on...
                        If only the Ruby console was multi lines. It's hard to edit in the small window.
                          I always edit my code in a Notepad++/TextWrangler window [with Ruby text-highlighting], then I copy/paste it into the Ruby Console's bottom bar + enter, to run it.
                          The Ruby Console accepts multi-line code if pasted, but you can only manually type in one line at a time!
                          • PixeroP
                            Pixero
                            I use Notepad++ as well but use the ruby code editor when testing out snippets without having to restart SketchUp.
                            Now I’ll continue with the main work.
