    Reading numbers from external text file
    18 Posts 2 Posters 8.7k Views 2 Watching
    • PixeroP
      Pixero
      Thanks, but I still get the Nil result even after removing the "Return 0".
      I even get it when running your code.
      For now I'm just experimenting with this part so there is no other code.
      The line I'm testing with looks like this:
          "x"; 3.4919929866069115,
        Did you use the whole code with p @settings at the end ?
        What do the first few lines of its output look like ?
        Also adding: puts @settings[2].split(' ')
        and puts @settings[2].split(' ')[1] to see what's up...
        • PixeroP
          Pixero
          ["{\n", "  \"principalPoint\"; {\n", "    \"x\"; 3.4919929866069115,\n", "    \"y\"; -0.017301744356540385\n", "  },\n", "  \"viewTransform\"; {\n", "    \"rows\"; [\n", "      [\n", "        -0.9075910551963806,\n", "        0.4198243379864999,\n", "        -0.005099192261283809,\n", "        -31.940051338855746\n", "      ],\n", "      [\n", "        0.00419330408856825,\n", "        -0.003080616899800699,\n", "        -0.9999864629085424,\n", "        -0.10391287329462531\n", "      ],\n", "      [\n", "        -0.4198343634438959,\n", "        -0.9076001515170179,\n", "        0.0010354892297866703,\n", "        -17.250974969132418\n", "      ],\n", "      [\n", "        0,\n", "        0,\n", "        0,\n", "        1\n", "      ]\n", "    ]\n", "  },\n", "  \"cameraTransform\"; {\n", "    \"rows\"; [\n", "      [\n", "        -0.9075910551963807,\n", "        0.00419330408856825,\n", "        -0.41983436344389585,\n", "        -36.23062125433451\n", "      ],\n", "      [\n", "        0.41982433798650004,\n", "        -0.0030806168998006997,\n", "        -0.9076001515170179,\n", "        -2.2480967029645083\n", "      ],\n", "      [\n", "        -0.005099192261283809,\n", "        -0.9999864629085424,\n", "        0.0010354892297866703,\n", "        -0.24891673044480064\n", "      ],\n", "      [\n", "        0,\n", "        0,\n", "        0,\n", "        1\n", "      ]\n", "    ]\n", "  },\n", "  \"horizontalFieldOfView\"; 0.9813963064459168,\n", "  \"verticalFieldOfView\"; 0.6616350540688956,\n", "  \"vanishingPoints\"; [\n", "    {\n", "      \"x\"; -0.5541295463355106,\n", "      \"y\"; 0.0013923823242965234\n", "    },\n", "    {\n", "      \"x\"; 4.357757655415969,\n", "      \"y\"; -0.02365461394665286\n", "    },\n", "    {\n", "      \"x\"; 12.708844850226638,\n", "      \"y\"; 1807.4703594352652\n", "    }\n", "  ],\n", "  \"vanishingPointAxes\"; [\n", "    \"xPositive\",\n", "    \"yPositive\",\n", "    \"zPositive\"\n", "  ],\n", "  \"relativeFocalLength\"; 1.8716593429474995,\n", "  \"imageWidth\"; 5000,\n", "  \"imageHeight\"; 3214\n", "}"]
          "[\"{\\n\", \"  \\\"principalPoint\\\"; {\\n\", \"    \\\"x\\\"; 3.4919929866069115,\\n\", \"    \\\"y\\\"; -0.017301744356540385\\n\", \"  },\\n\", \"  \\\"viewTransform\\\"; {\\n\", \"    \\\"rows\\\"; [\\n\", \"      [\\n\", \"        -0.9075910551963806,\\n\", \"        0.4198243379864999,\\n\", \"        -0.005099192261283809,\\n\", \"        -31.940051338855746\\n\", \"      ],\\n\", \"      [\\n\", \"        0.00419330408856825,\\n\", \"        -0.003080616899800699,\\n\", \"        -0.9999864629085424,\\n\", \"        -0.10391287329462531\\n\", \"      ],\\n\", \"      [\\n\", \"        -0.4198343634438959,\\n\", \"        -0.9076001515170179,\\n\", \"        0.0010354892297866703,\\n\", \"        -17.250974969132418\\n\", \"      ],\\n\", \"      [\\n\", \"        0,\\n\", \"        0,\\n\", \"        0,\\n\", \"        1\\n\", \"      ]\\n\", \"    ]\\n\", \"  },\\n\", \"  \\\"cameraTransform\\\"; {\\n\", \"    \\\"rows\\\"; [\\n\", \"      [\\n\", \"        -0.9075910551963807,\\n\", \"        0.00419330408856825,\\n\", \"        -0.41983436344389585,\\n\", \"        -36.23062125433451\\n\", \"      ],\\n\", \"      [\\n\", \"        0.41982433798650004,\\n\", \"        -0.0030806168998006997,\\n\", \"        -0.9076001515170179,\\n\", \"        -2.2480967029645083\\n\", \"      ],\\n\", \"      [\\n\", \"        -0.005099192261283809,\\n\", \"        -0.9999864629085424,\\n\", \"        0.0010354892297866703,\\n\", \"        -0.24891673044480064\\n\", \"      ],\\n\", \"      [\\n\", \"        0,\\n\", \"        0,\\n\", \"        0,\\n\", \"        1\\n\", \"      ]\\n\", \"    ]\\n\", \"  },\\n\", \"  \\\"horizontalFieldOfView\\\"; 0.9813963064459168,\\n\", \"  \\\"verticalFieldOfView\\\"; 0.6616350540688956,\\n\", \"  \\\"vanishingPoints\\\"; [\\n\", \"    {\\n\", \"      \\\"x\\\"; -0.5541295463355106,\\n\", \"      \\\"y\\\"; 0.0013923823242965234\\n\", \"    },\\n\", \"    {\\n\", \"      \\\"x\\\"; 4.357757655415969,\\n\", \"      \\\"y\\\"; -0.02365461394665286\\n\", \"    },\\n\", \"    {\\n\", \"      \\\"x\\\"; 12.708844850226638,\\n\", \"      \\\"y\\\"; 1807.4703594352652\\n\", \"    }\\n\", \"  ],\\n\", \"  \\\"vanishingPointAxes\\\"; [\\n\", \"    \\\"xPositive\\\",\\n\", \"    \\\"yPositive\\\",\\n\", \"    \\\"zPositive\\\"\\n\", \"  ],\\n\", \"  \\\"relativeFocalLength\\\"; 1.8716593429474995,\\n\", \"  \\\"imageWidth\\\"; 5000,\\n\", \"  \\\"imageHeight\\\"; 3214\\n\", \"}\"]"
          • PixeroP
            Pixero
            3.4919929866069115
            "x";
            3.4919929866069115,
            "Nil result (no result returned or run failed)"
            • PixeroP
              Pixero
              3.4919929866069115
              3.4919929866069115,
              • PixeroP
                Pixero
                Here is the txt file I'm loading. (It's a json file from the beginning.)
                test1.txt
                  Are you running this in the Ruby Console, or in some other console extension ?
                  Try this without the ' def'
                  filepath = UI.openpanel("Open File", "C;/", "TXT|*.txt||")
                  if filepath ### allows user to Cancel
                    settings = File.readlines(filepath)
                    puts settings[2].split(' ')[1].to_f
                  else
                    puts "Canceled!"
                    Our posts crossed.
                    Both my versions of the code work fine with your TXT file, with no error [in Ruby Console].
                    So do you use a console-app ?
                    • PixeroP
                      Pixero
                      Interesting.
                      Running your latest code in the console works but running it in SketchUp Ruby Code Editor by Alexander Schreyer gives the Nil result also.
                      I also tried your first version in the console and it worked without errors.
                      So is it safe to continue if it's just something in his Code editor app that causes the Nil result?
                        Most of these console-apps are not perfect...
                        I only ever use the Ruby Console.
                        • PixeroP
                          Pixero
                          Thanks for all the help so far. I'm sure there will be more later on...
                          If only the Ruby console was multi lines. It's hard to edit in the small window.
                            I always edit my code in a Notepad++/TextWrangler window [with Ruby text-highlighting], then I copy/paste it into the Ruby Console's bottom bar + enter, to run it.
                            The Ruby Console accepts multi-line code if pasted, but you can only manually type in one line at a time!
                            • PixeroP
                              Pixero
                              I use Notepad++ as well but use the ruby code editor when testing out snippets without having to restart SketchUp.
                              Now I’ll continue with the main work.
