    Reading numbers from external text file
    18 Posts 2 Posters 8.5k Views 2 Watching
    • PixeroP Offline
      Pixero
      ["{\n", "  \"principalPoint\"; {\n", "    \"x\"; 3.4919929866069115,\n", "    \"y\"; -0.017301744356540385\n", "  },\n", "  \"viewTransform\"; {\n", "    \"rows\"; [\n", "      [\n", "        -0.9075910551963806,\n", "        0.4198243379864999,\n", "        -0.005099192261283809,\n", "        -31.940051338855746\n", "      ],\n", "      [\n", "        0.00419330408856825,\n", "        -0.003080616899800699,\n", "        -0.9999864629085424,\n", "        -0.10391287329462531\n", "      ],\n", "      [\n", "        -0.4198343634438959,\n", "        -0.9076001515170179,\n", "        0.0010354892297866703,\n", "        -17.250974969132418\n", "      ],\n", "      [\n", "        0,\n", "        0,\n", "        0,\n", "        1\n", "      ]\n", "    ]\n", "  },\n", "  \"cameraTransform\"; {\n", "    \"rows\"; [\n", "      [\n", "        -0.9075910551963807,\n", "        0.00419330408856825,\n", "        -0.41983436344389585,\n", "        -36.23062125433451\n", "      ],\n", "      [\n", "        0.41982433798650004,\n", "        -0.0030806168998006997,\n", "        -0.9076001515170179,\n", "        -2.2480967029645083\n", "      ],\n", "      [\n", "        -0.005099192261283809,\n", "        -0.9999864629085424,\n", "        0.0010354892297866703,\n", "        -0.24891673044480064\n", "      ],\n", "      [\n", "        0,\n", "        0,\n", "        0,\n", "        1\n", "      ]\n", "    ]\n", "  },\n", "  \"horizontalFieldOfView\"; 0.9813963064459168,\n", "  \"verticalFieldOfView\"; 0.6616350540688956,\n", "  \"vanishingPoints\"; [\n", "    {\n", "      \"x\"; -0.5541295463355106,\n", "      \"y\"; 0.0013923823242965234\n", "    },\n", "    {\n", "      \"x\"; 4.357757655415969,\n", "      \"y\"; -0.02365461394665286\n", "    },\n", "    {\n", "      \"x\"; 12.708844850226638,\n", "      \"y\"; 1807.4703594352652\n", "    }\n", "  ],\n", "  \"vanishingPointAxes\"; [\n", "    \"xPositive\",\n", "    \"yPositive\",\n", "    \"zPositive\"\n", "  ],\n", "  \"relativeFocalLength\"; 1.8716593429474995,\n", "  \"imageWidth\"; 5000,\n", "  \"imageHeight\"; 3214\n", "}"]
      "[\"{\\n\", \"  \\\"principalPoint\\\"; {\\n\", \"    \\\"x\\\"; 3.4919929866069115,\\n\", \"    \\\"y\\\"; -0.017301744356540385\\n\", \"  },\\n\", \"  \\\"viewTransform\\\"; {\\n\", \"    \\\"rows\\\"; [\\n\", \"      [\\n\", \"        -0.9075910551963806,\\n\", \"        0.4198243379864999,\\n\", \"        -0.005099192261283809,\\n\", \"        -31.940051338855746\\n\", \"      ],\\n\", \"      [\\n\", \"        0.00419330408856825,\\n\", \"        -0.003080616899800699,\\n\", \"        -0.9999864629085424,\\n\", \"        -0.10391287329462531\\n\", \"      ],\\n\", \"      [\\n\", \"        -0.4198343634438959,\\n\", \"        -0.9076001515170179,\\n\", \"        0.0010354892297866703,\\n\", \"        -17.250974969132418\\n\", \"      ],\\n\", \"      [\\n\", \"        0,\\n\", \"        0,\\n\", \"        0,\\n\", \"        1\\n\", \"      ]\\n\", \"    ]\\n\", \"  },\\n\", \"  \\\"cameraTransform\\\"; {\\n\", \"    \\\"rows\\\"; [\\n\", \"      [\\n\", \"        -0.9075910551963807,\\n\", \"        0.00419330408856825,\\n\", \"        -0.41983436344389585,\\n\", \"        -36.23062125433451\\n\", \"      ],\\n\", \"      [\\n\", \"        0.41982433798650004,\\n\", \"        -0.0030806168998006997,\\n\", \"        -0.9076001515170179,\\n\", \"        -2.2480967029645083\\n\", \"      ],\\n\", \"      [\\n\", \"        -0.005099192261283809,\\n\", \"        -0.9999864629085424,\\n\", \"        0.0010354892297866703,\\n\", \"        -0.24891673044480064\\n\", \"      ],\\n\", \"      [\\n\", \"        0,\\n\", \"        0,\\n\", \"        0,\\n\", \"        1\\n\", \"      ]\\n\", \"    ]\\n\", \"  },\\n\", \"  \\\"horizontalFieldOfView\\\"; 0.9813963064459168,\\n\", \"  \\\"verticalFieldOfView\\\"; 0.6616350540688956,\\n\", \"  \\\"vanishingPoints\\\"; [\\n\", \"    {\\n\", \"      \\\"x\\\"; -0.5541295463355106,\\n\", \"      \\\"y\\\"; 0.0013923823242965234\\n\", \"    },\\n\", \"    {\\n\", \"      \\\"x\\\"; 4.357757655415969,\\n\", \"      \\\"y\\\"; -0.02365461394665286\\n\", \"    },\\n\", \"    {\\n\", \"      \\\"x\\\"; 12.708844850226638,\\n\", \"      \\\"y\\\"; 1807.4703594352652\\n\", \"    }\\n\", \"  ],\\n\", \"  \\\"vanishingPointAxes\\\"; [\\n\", \"    \\\"xPositive\\\",\\n\", \"    \\\"yPositive\\\",\\n\", \"    \\\"zPositive\\\"\\n\", \"  ],\\n\", \"  \\\"relativeFocalLength\\\"; 1.8716593429474995,\\n\", \"  \\\"imageWidth\\\"; 5000,\\n\", \"  \\\"imageHeight\\\"; 3214\\n\", \"}\"]"
      • PixeroP Offline
        Pixero
        3.4919929866069115
        "x";
        3.4919929866069115,
        "Nil result (no result returned or run failed)"
        • PixeroP Offline
          Pixero
          3.4919929866069115
          3.4919929866069115,
          • PixeroP Offline
            Pixero
            Here is the txt file I'm loading. (It's a json file from the beginning.)
            test1.txt
              Are you running this in the Ruby Console, or in some other console extension ?
              Try this without the ' def'
              filepath = UI.openpanel("Open File", "C;/", "TXT|*.txt||")
              if filepath ### allows user to Cancel
                settings = File.readlines(filepath)
                puts settings[2].split(' ')[1].to_f
              else
                puts "Canceled!"
                Our posts crossed.
                Both my versions of the code work fine with your TXT file, with no error [in Ruby Console].
                So do you use a console-app ?
                • PixeroP Offline
                  Pixero
                  Interesting.
                  Running your latest code in the console works but running it in SketchUp Ruby Code Editor by Alexander Schreyer gives the Nil result also.
                  I also tried your first version in the console and it worked without errors.
                  So is it safe to continue if it's just something in his Code editor app that causes the Nil result?
                    Most of these console-apps are not perfect...
                    I only ever use the Ruby Console.
                    ๐Ÿ˜‰
                    • PixeroP Offline
                      Pixero
                      Thanks for all the help so far. I'm sure there will be more later on...
                      If only the Ruby console was multi lines. It's hard to edit in the small window.
                        I always edit my code in a Notepad++/TextWrangler window [with Ruby text-highlighting], then I copy/paste it into the Ruby Console's bottom bar + enter, to run it.
                        The Ruby Console accepts multi-line code if pasted, but you can only manually type in one line at a time!
                        • PixeroP Offline
                          Pixero
                          I use Notepad++ as well but use the ruby code editor when testing out snippets without having to restart SketchUp.
                          Now Iโ€™ll continue with the main work.
