    Model steam engine
    26 Posts 9 Posters 6.9k Views 9 Watching
      shawb
      'Meccano' was, and still is, a very popular construction toy with a large following on the web today. The model shown is based on a design from the 1960/70s. I added a generic oil lamp for illumination. I hope you will enjoy these renders.
      Regards to all
      Sketchup Pro 2018
      SU Podium Pro
      Sketchup Texture Club
      • BoxB Offline
        That's really quite nice, but personally I would say the oil lamp is detracting from the scene. It overpowers the real subject and the glass it not right for such a lamp. I find I can't look at anything but the lamp glass.
          shawb
          That's a fair comment Box - the 'two for one' idea didn't quite work then!
            Hi nice work ๐Ÿ‘ I agree though that the engine should be the hero and perhaps some close ups as well? Perhaps even if it was driving something "meccano" Perhaps and/also some meccano parts washers/nuts bolts ect. I had one of those steam enines as a child:) I would leave the lamp out.
              I agree, engine minus lamp but going the right way render wise.
                shawb
                Thanks to all for the constructive comments. My Projects folder is littered with models that became too complex and unwieldy because I always end up putting in more than is needed. Hence the inclusion of the lamp. L i am's suggestion for further modelling is very tempting but would I end up with a de-luxe virtual Meccano set? ๐Ÿ˜‰
                Attached renders (two posts) with only the engine and, I hope, a simpler presentation.
                  shawb
                  Two more renders
                    shawb
                    A short animation of the steam engine using the SU native Scenes and Export animation to image set. A little post processing in Photoshop and saved as a GIF. I did try using Fredo6's Animator and although I could get all the parts to move as required I could not get them to work together in sequence, I think the math involved is a bit beyond me! Anyhow, here it is.
                    Click on the GIF to view.
                    A very Happy New Year to all.
                      db11
                      Cool animation and a very nostalgia-inducing model!
                      I spent many childhood hours constructing various Meccano models, so your SU steam engine invokes a lot of pleasant memories.
                      Well done! Oh, and Happy New Year!
                        shawb
                        Thank you db11, I did try a rendered version but the NVR worked better. I too remember playing with Meccano and realise that it had given me a great start for when I entered the world of work.
                        • Bryan KB Offline
                          Very cool!
                            shawb
                            Thank you Bryan K, maybe this year's project should be improving my maths as well as SU.
                            • majidM Offline
                              majid
                              Regards to all
                              Sketchup Pro 2018
                              SU Podium Pro
                              If I wanna help pushing your renders to next level I'd add these comments:
                              Metal part of the lamp need more attention/ reflection ...
                              Wood bump map is somehow strong.
                              Glass part of the lamp could be better in 2 ways: A- if you are going to use a thick glass material, then the modle must be based on real world: A thin thickness glass.
                              B- If you are not going to consider the thickness then apply "thin/architectural" glass template to it.
                              Fine bevels of the engine model also will rocket up the realism.
                                Cool animation! โ˜€
                                Curious there is not a builder online like Lego Designer
                                (who seems also not more existing online)... ๐Ÿ˜ฎ
                                http://www.meccano.com ๐Ÿ˜‰
                                  shawb
                                  Majid & Pilou, thank you both for your comments. Yes, the wood texture bump map was a bit too strong and I will try some experimentation with the chimney glass texture.
                                    shawb
                                    Taking on board Majid's suggestions I have done some work on the oil lamp and hope it shows some improvement!
                                      Very nice, I think you need a dirt map and reduced shine on the lamp body.
                                        shawb
                                        Thanks Mike but I have spent hours with rag and tin of 'Brasso' making it that clean and shiny! ๐Ÿ˜‰
                                        A bit of dirt would be a good next step I agree and, to my mind, the harder look to achieve. I will give it a go when I can.
                                          shawb
                                          Earlier, L i am suggested something 'Meccano' for the steam engine to drive. Here are some rough renders of the stamping press (what I would call it anyway) along with the engine. No driving band as yet or animation.
                                            shawb
                                            Some NPR images of a different engine model with line shaft, stamping press and trip hammer.
                                            • 1 / 2
