    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Model steam engine
    26 Posts 9 Posters 6.5k Views 9 Watching
      shawb
      Thank you db11, I did try a rendered version but the NVR worked better. I too remember playing with Meccano and realise that it had given me a great start for when I entered the world of work.
      • Bryan KB Offline
        Very cool!
          shawb
          Thank you Bryan K, maybe this year's project should be improving my maths as well as SU.
          • majidM Offline
            majid
            @shawb said:
            'Meccano' was, and still is, a very popular construction toy with a large following on the web today. The model shown is based on a design from the 1960/70s. I added a generic oil lamp for illumination. I hope you will enjoy these renders.
            Regards to all
            Sketchup Pro 2018
            SU Podium Pro
            Sketchup Texture Club
            If I wanna help pushing your renders to next level I'd add these comments:
            Metal part of the lamp need more attention/ reflection ...
            Wood bump map is somehow strong.
            Glass part of the lamp could be better in 2 ways: A- if you are going to use a thick glass material, then the modle must be based on real world: A thin thickness glass.
            B- If you are not going to consider the thickness then apply "thin/architectural" glass template to it.
            Fine bevels of the engine model also will rocket up the realism.
              Cool animation! โ˜€
              Curious there is not a builder online like Lego Designer
              (who seems also not more existing online)... ๐Ÿ˜ฎ
              http://www.meccano.com ๐Ÿ˜‰
                shawb
                Majid & Pilou, thank you both for your comments. Yes, the wood texture bump map was a bit too strong and I will try some experimentation with the chimney glass texture.
                  shawb
                  Taking on board Majid's suggestions I have done some work on the oil lamp and hope it shows some improvement!
                    Very nice, I think you need a dirt map and reduced shine on the lamp body.
                      shawb
                      Thanks Mike but I have spent hours with rag and tin of 'Brasso' making it that clean and shiny! ๐Ÿ˜‰
                      A bit of dirt would be a good next step I agree and, to my mind, the harder look to achieve. I will give it a go when I can.
                        shawb
                        Earlier, L i am suggested something 'Meccano' for the steam engine to drive. Here are some rough renders of the stamping press (what I would call it anyway) along with the engine. No driving band as yet or animation.
                          shawb
                          Some NPR images of a different engine model with line shaft, stamping press and trip hammer.
                          • HornOxxH Offline
                            HornOxx
                            ๐Ÿ‘ prima! I love it ! ๐Ÿ˜„
                            never trust a skinny cook
                              shawb
                              Thank you HornOxx. Also, a big 'thank you' to all the contributors to the Forum who provide so much inspiration and sharing of knowledge. I am often humbled by the shear excellence that they produce.
                                A fascinating and wonderful piece, nice one. ๐Ÿ˜Ž
                                  shawb
                                  Thanks Mike, although I grew up with basic Meccano the steam engines and machines were definitely way out of my reach but I suppose I can have as many as I want now with a bit of Sketchup!
                                  • Bryan KB Offline
                                    Those turned out great!
                                      shawb
                                      Thank you Bryan, now wondering where to go next! I have a notion for one particular model but it will depend on the available source material. I was looking at your excellent Blog page this very morning, you're range of transport covers a, somewhat, greater span of years than mine; 2000 year old Chinese tricycles to spaceships. I consider myself to be definitely stuck in the steam age!
