    Model steam engine
    26 Posts 9 Posters 7.6k Views 9 Watching
      db11
      Cool animation and a very nostalgia-inducing model!
      I spent many childhood hours constructing various Meccano models, so your SU steam engine invokes a lot of pleasant memories.
      Well done! Oh, and Happy New Year!
        shawb
        Thank you db11, I did try a rendered version but the NVR worked better. I too remember playing with Meccano and realise that it had given me a great start for when I entered the world of work.
        • Bryan KB
          Very cool!
            shawb
            Thank you Bryan K, maybe this year's project should be improving my maths as well as SU.
            • majidM
              majid
              @shawb said:
              'Meccano' was, and still is, a very popular construction toy with a large following on the web today. The model shown is based on a design from the 1960/70s. I added a generic oil lamp for illumination. I hope you will enjoy these renders.
              Regards to all
              Sketchup Pro 2018
              SU Podium Pro
              Sketchup Texture Club
              If I wanna help pushing your renders to next level I'd add these comments:
              Metal part of the lamp need more attention/ reflection ...
              Wood bump map is somehow strong.
              Glass part of the lamp could be better in 2 ways: A- if you are going to use a thick glass material, then the modle must be based on real world: A thin thickness glass.
              B- If you are not going to consider the thickness then apply "thin/architectural" glass template to it.
              Fine bevels of the engine model also will rocket up the realism.
                Cool animation! โ˜€
                Curious there is not a builder online like Lego Designer
                (who seems also not more existing online)... ๐Ÿ˜ฎ
                http://www.meccano.com ๐Ÿ˜‰
                  shawb
                  Majid & Pilou, thank you both for your comments. Yes, the wood texture bump map was a bit too strong and I will try some experimentation with the chimney glass texture.
                    shawb
                    Taking on board Majid's suggestions I have done some work on the oil lamp and hope it shows some improvement!
                      Very nice, I think you need a dirt map and reduced shine on the lamp body.
                        shawb
                        Thanks Mike but I have spent hours with rag and tin of 'Brasso' making it that clean and shiny! ๐Ÿ˜‰
                        A bit of dirt would be a good next step I agree and, to my mind, the harder look to achieve. I will give it a go when I can.
                          shawb
                          Earlier, L i am suggested something 'Meccano' for the steam engine to drive. Here are some rough renders of the stamping press (what I would call it anyway) along with the engine. No driving band as yet or animation.
                            shawb
                            Some NPR images of a different engine model with line shaft, stamping press and trip hammer.
                            • HornOxxH
                              HornOxx
                              ๐Ÿ‘ prima! I love it ! ๐Ÿ˜„
                              never trust a skinny cook
                                shawb
                                Thank you HornOxx. Also, a big 'thank you' to all the contributors to the Forum who provide so much inspiration and sharing of knowledge. I am often humbled by the shear excellence that they produce.
                                  A fascinating and wonderful piece, nice one. ๐Ÿ˜Ž
                                    shawb
                                    Thanks Mike, although I grew up with basic Meccano the steam engines and machines were definitely way out of my reach but I suppose I can have as many as I want now with a bit of Sketchup!
                                    • Bryan KB
                                      Those turned out great!
                                        shawb
                                        Thank you Bryan, now wondering where to go next! I have a notion for one particular model but it will depend on the available source material. I was looking at your excellent Blog page this very morning, you're range of transport covers a, somewhat, greater span of years than mine; 2000 year old Chinese tricycles to spaceships. I consider myself to be definitely stuck in the steam age!
