    Model steam engine
    26 Posts 9 Posters 7.5k Views 9 Watching
      shawb
      Thanks to all for the constructive comments. My Projects folder is littered with models that became too complex and unwieldy because I always end up putting in more than is needed. Hence the inclusion of the lamp. L i am's suggestion for further modelling is very tempting but would I end up with a de-luxe virtual Meccano set? ๐Ÿ˜‰
      Attached renders (two posts) with only the engine and, I hope, a simpler presentation.
        shawb
        Two more renders
          shawb
          A short animation of the steam engine using the SU native Scenes and Export animation to image set. A little post processing in Photoshop and saved as a GIF. I did try using Fredo6's Animator and although I could get all the parts to move as required I could not get them to work together in sequence, I think the math involved is a bit beyond me! Anyhow, here it is.
          Click on the GIF to view.
          A very Happy New Year to all.
            db11
            Cool animation and a very nostalgia-inducing model!
            I spent many childhood hours constructing various Meccano models, so your SU steam engine invokes a lot of pleasant memories.
            Well done! Oh, and Happy New Year!
              shawb
              Thank you db11, I did try a rendered version but the NVR worked better. I too remember playing with Meccano and realise that it had given me a great start for when I entered the world of work.
              • Bryan KB Offline
                Very cool!
                  shawb
                  Thank you Bryan K, maybe this year's project should be improving my maths as well as SU.
                  • majidM Offline
                    majid
                    @shawb said:
                    'Meccano' was, and still is, a very popular construction toy with a large following on the web today. The model shown is based on a design from the 1960/70s. I added a generic oil lamp for illumination. I hope you will enjoy these renders.
                    Regards to all
                    Sketchup Pro 2018
                    SU Podium Pro
                    Sketchup Texture Club
                    If I wanna help pushing your renders to next level I'd add these comments:
                    Metal part of the lamp need more attention/ reflection ...
                    Wood bump map is somehow strong.
                    Glass part of the lamp could be better in 2 ways: A- if you are going to use a thick glass material, then the modle must be based on real world: A thin thickness glass.
                    B- If you are not going to consider the thickness then apply "thin/architectural" glass template to it.
                    Fine bevels of the engine model also will rocket up the realism.
                      Cool animation! โ˜€
                      Curious there is not a builder online like Lego Designer
                      (who seems also not more existing online)... ๐Ÿ˜ฎ
                      http://www.meccano.com ๐Ÿ˜‰
                        shawb
                        Majid & Pilou, thank you both for your comments. Yes, the wood texture bump map was a bit too strong and I will try some experimentation with the chimney glass texture.
                          shawb
                          Taking on board Majid's suggestions I have done some work on the oil lamp and hope it shows some improvement!
                            Very nice, I think you need a dirt map and reduced shine on the lamp body.
                              shawb
                              Thanks Mike but I have spent hours with rag and tin of 'Brasso' making it that clean and shiny! ๐Ÿ˜‰
                              A bit of dirt would be a good next step I agree and, to my mind, the harder look to achieve. I will give it a go when I can.
                                shawb
                                Earlier, L i am suggested something 'Meccano' for the steam engine to drive. Here are some rough renders of the stamping press (what I would call it anyway) along with the engine. No driving band as yet or animation.
                                  shawb
                                  Some NPR images of a different engine model with line shaft, stamping press and trip hammer.
                                  • HornOxxH Offline
                                    HornOxx
                                    ๐Ÿ‘ prima! I love it ! ๐Ÿ˜„
                                    never trust a skinny cook
                                      shawb
                                      Thank you HornOxx. Also, a big 'thank you' to all the contributors to the Forum who provide so much inspiration and sharing of knowledge. I am often humbled by the shear excellence that they produce.
                                        A fascinating and wonderful piece, nice one. ๐Ÿ˜Ž
                                          shawb
                                          Thanks Mike, although I grew up with basic Meccano the steam engines and machines were definitely way out of my reach but I suppose I can have as many as I want now with a bit of Sketchup!
                                          • Bryan KB Offline
                                            Those turned out great!
