    Ruby access to Export Animation?
    2 Posts 2 Posters 853 Views 2 Watching
    • oceanembersO
      oceanembers
      I have a model with a lot of scenes. For each scene, I have to save an animation from camera position 1 to camera position 2 (about a 30 second transition). This is easy enough to do manually, but I have to be there the entire time.
      My question is: is it is possible to Export Animation via the ruby API? Is it possible to monitor when the export is complete? And can I therefore write a script that will loop through each of the relevant scenes, exporting animation on each one?
      I did have a look through the API, but I'm afraid I'm not super familiar with it and couldn't find what I was looking for.
      • TIGT
        Fredo's Animator allows you to animate objects and camera, so if you leave the objects alone you should be able to animate between the scene's cameras.
        But nothing is done with no work...
        SketchUp Plugins | PluginStore | SketchUcation
        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
        (sketchucation.com)
