    Error with generating report
    13 Posts 2 Posters 9.0k Views 2 Watching
    • P
      pibuz
      Hi guys, i just installed SU2018, but somehow the report utility fails to load..
      The ruby console throws this message
      "Error: #<NoMethodError: undefined method to_json' for #<Hash:0x0002a849deeb78>> c:/users/filip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/generatereport.rbe:359:in pull_attribute_tree'
      c:/users/filip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/generatereport.rbe:94:in block in initialize' SketchUp:1:in call'"
      Any ideas about how I can fix it?
      Thanks in advance!
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
      • jujuJ
        juju
        @pibuz said:
        Hi just installed SU2018
        Did you install via right click > run as administrator? If not then do this and do a repair installation. Else just reinstall using this method.
        • P
          pibuz
          I'll retry immediately, just to make sure...
          • P
            pibuz
            Nothing.
            And now SketchUp freezes, and can't continue.
            I'm astonished. The Laptop is completely new, and SketchUp refuses to work. I truly don't know what to do.....
            • jujuJ
              juju
              What are the specifications of the new machine? I assume it is a windows machine? Have you restarted inbetween?
              • P
                pibuz
                The Machine is very powerful, it absolutely not an hardware problem. Moreover, I'm a very long time SU user, so really BASIC operations like installing and opening the program should be absurdly easy.
                And yet, it doesn't work....I don't know why...
                I tried uninstalling and reinstalling but this doesn't fix anything.......
                • jujuJ
                  juju
                  Yeah, I know you're a long time SU user pibuz (with some nice stuff as well), just trying to help.
                  Maybe try to get SketchUp to make good on their support & maintenance?
                  Hmmm. How's your internet connection / connectivity? I've had some strange error messages from SU when this is compromised. Whenever the internet connectivity is strong / fine there doesn't seem to be problem error messages. Also when it's off (no internet connected) I don't have error messages, just when connectivity is compromised. This not the case here either?
                  • P
                    pibuz
                    Connection also is excellent!
                    When trying to uninstall/re-install the first time I run the program it's ok, the second time it starts freezing......
                    maybe it's something related to the license check? Maybe a difficult check due to restrictions in outgoing signals of OUR firewall?
                    • P
                      pibuz
                      ...seems like I can't even open a sketchup file now....
                      I begin to think the issue here is the integrated video card drivers...... I'm running on a UHD graphics 630..... is there something I can do to fix this?
                      I can't work at all....
                      • jujuJ
                        juju
                        Please tell me the laptop has a dedicated GFX solution? You'll need to set preferences making SU / LO run only on dedicated GFX solution.
                        • P
                          pibuz
                          Obviously yes: there's a GTX 1050 with 4GB dedicated.
                          Yesterday evening I kept on testing the issues: I can install and run SketchUp 2017, but I cannot launch Indigo renderer and enscape. Both freeze...... πŸ˜•
                          EDIT: sorry Juju: what's "LO"?
                          • jujuJ
                            juju
                            SU = SketchUp
                            LO = LayOut
                            • P
                              pibuz
                              Thanks! Strangely, layout shows no issues. At all.
