    SketchUp 2019 release
    430 Posts 94 Posters 343.6k Views 94 Watching
    • F Offline
      function
      @utiler said:
      @jakemm said:
      Small feature request, but I'd like the ability to show area in a different measurement to the drawing dimensions.
      I'm not sure how things work in America, but in the UK and Europe detailed architectural work is drawn in millimetres, and square metres are used for areas.
      When a client asks: how much paint do I need, seeing 8483472mm2 is quite confusing. I currently have to switch the drawing units, see that it's 8.5m2, then convert back to mm to continue modelling.
      YES!!! This is very very annoying...
      use Matt666's Toggle Units plugin. It's very useful and it solves the area display problem too.
      https://sketchucation.com/pluginstore?pln=Matt_Toggle_Units
      where is sketchup 2019!?
      too many people are spending time making youtube videos for their channel instead of working on the program โ“ โ—
      • G Offline
        Glenn at home
        @freebs said:
        Before you even contemplate that one, you should take a look at FormZ ...
        Agreed. The built-in tools that don't come with SU are impressive. The stair tool is a good one. Not perfect but easy too use. The built-in Subdivision and Subdivision Edit tools are also great. Some of the editing and controls are a bit different as compared to SU. The real plus is the option of 3 levels of product. They have the Pro with ALL the bells and whistles, Jr which has a slimmed down tool set and then a free offering. All 3 are available for ANY use what-so-ever! So yes, you can use Free for commercial work if you want to (shock!). The Pro also has a Layout tools as well. All 3 will import DWG files but only the paid versions can export DWG.
        • fredo6F Offline
          fredo6
          You could try FredoTools::ReportLabelArea, which includes reports on areas by material, layer, etc..., as well as an interactive tool to display areas by hovering over the model. All with choice of units, regardless of the model units. You can also label face(s) easily with their area.
            alpro
            Ok my guess is Dec 17th
              tktechie
              Aaaaaand
              The 17th has come and gone!
              sad
              • PixeroP Offline
                Pixero
                I just got a SketchUp newsletter for December without any mention of a new version.
                • ntxdaveN Offline
                  ntxdave
                  Can you say Happy New Year? At least that is my latest guess. ๐Ÿ˜„
                  Press F1...thank me later
                    samnorth
                    SU2019 in...2019 ๐Ÿ˜ฎ
                    Surely it'll have to be SU2020 to be current? ๐Ÿ˜‰
                    • david_hD Offline
                      david_h
                      They still do the newsletter? I haven't gotten one of those in ages! I don't remember unsubscribing. Unless it's a different one.
                        mpacey
                        I'm just going to keep saying tomorrow, every day, until it happens.
                          Like saying "Free beer, tomorrow." ๐Ÿ˜„
                            Tony.3ds
                            I am a little disappointed... Sketchup is an important tool in my professional work flow too and i think developers should use these newlesters to communicate about the future of this soft instead of just showing what most people already know.
                            Win10 64bits | Intel Core i7 4790k 4 GHz | NVIDIA GTX 970 | 16 Go DDR3
                            iMac Retina 5K OSX 10.13.6 | Intel Core i7 4 GHz | AMD Radeon R9 | 16 Go DDR3
                              samnorth
                              There's a similar thread on the SUForum with some input from the SUTeam
                              https://forums.sketchup.com/t/sketchup-pro-future/82761/84
                              • F Offline
                                function
                                skp boulder is too busy making lame youtube videos
                                  alpro
                                  Ok new guess is Jan 14
                                  • K Offline
                                    kaas
                                    I see several Fredo plugins are getting updates these days which could be related (and also could mean some plugins might need some v19 adjustments to work again...)
                                    So somewhere in Jan sounds reasonable.
                                      Or it could just mean he's doing bug fixes and other cleanup. Fredo is always fine tuning his extensions to make them run better or do more things. ๐Ÿ˜‰
                                        samnorth
                                        Advanced Camera Tools too... [26 November]
                                        • pbacotP Offline
                                          He's been trying to fix a problem with MacOS or Safari.
                                          • R Do not disturb
                                            rv1974
                                            @rv1974 said:
                                            Meanwhile Whaat is teasing with some GAME CHAGER before the end of 2018. Highly likely there will be x10 more features than in SU19 (sadly)
                                            Hm I guessed it will be something similar to Grasshopper
                                            • 6
                                            • 7
                                            • 21
                                            • 22
                                            • 5 / 22
