    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 613.5k Views 151 Watching
    • fredo6F Offline
      fredo6
      NEW RELEASE: FredoCorner v1.8a - 26 Apr 20
      Requirement: LibFredo6 9.1b
      FredoCorner 1.8a is a major release
      • Disabled the possibility to round new corners in the same session. When corners are generated, you have the option to modify the parameters ('Apply Change') or to Exit (Double-Click).
      • Correction for the Bevel tool at triangulated corners. Bevel are now made of a single face, possibly triangulated, except when the bordering faces do not have the same material.
      Please note that, in the current version of FredoCorner:
      • there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
      • there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
      • Terminal corners (that is ending on a single edge) may present issues and bugs
      • No documentation yet, so watch the videos that I will publish.
      Please report issues, questions and any feedback in the present thread
      Home Page of FredoCorner for information and Download.
      Main post of this FredoCorner thread.
      • E Offline
        Einstein
        Thank you so much! I needed this change a lot πŸ˜„
        Your fantastic tools are like air to me.
          comsasa
          FredoCorner v1.8a & LibFredo6 v10.5a User.
          I want the edge color to appear as the sketchup default.
          At the moment of using the Fredocorner brown, magenta, red and violet materials appear in the material window.
          I don't want this to appear. What should I do?
            First show an example of what you are seeing.
            What version of SketchUp are you using. Your profile says "2019 Free/Make" but there is no such version.
            • fredo6F Offline
              fredo6
              NEW RELEASE: FredoCorner v1.8b - 28 May 20
              FredoCorner 1.8b is a maintenance release fixing an issue with improper coloring of edges
              • fredo6F Offline
                fredo6
                Sorry for that. I use colors for debugging purpose and apparently I left them in the published version.
                This is fixed in FredoCorner v1.8b
                Fredo
                • fredo6F Offline
                  fredo6
                  NEW RELEASE: FredoCorner v1.9a - 19 Jun 20
                  Requirement: LibFredo6 10.7a
                  FredoCorner 1.9a is a maintenance release
                  • fixing an issue with reselection of edges after a Repair - Edit
                  • Exit via a single click
                    sehuz
                    Hello. Great job with this amazing tool Fredo !
                    I'v just installed today and test it with the direct link for Twinmotion, sadly the beveling doesn't appear, and also it shows issues on the geometry.
                    But exporting the model to Twinmotion it works great.
                    • fredo6F Offline
                      fredo6
                      What is this "direct link for Twinmotion"?
                      Did you generate the geometry or just activate the Preview mode (whihc is just drawing, not generating geometry)?
                      • fredo6F Offline
                        fredo6
                        NEW RELEASE: FredoCorner v2.0a - 19 Aug 20
                        Requirement: LibFredo6 11.0a
                        FredoCorner 2.0a is a maintenance release
                        • Improvement of Orbit/Pan on Windows for Preview mode
                        • Extension of validity
                          rv1974
                          Fredo, could you make the offset faces stay selected after command is executed please? Just like you did in JPP. It'd help tremendously to do some nice things with this separated selection.
                          P.S. You are one step πŸ˜„ from making long awaited Groove maker. All it takes is to add is to add 'ignore hard\open edges' option***** in pre-selected geometry and integrate merge coplanar offset faces and JPP inwards.
                          *- In his video, Ahmed solves this ignoring problem by drawing initial groove lines on separate tag.
                            Or you have another trick πŸ˜‰
                            Make 2 same volumes at the same place !
                            Fractalize one then Exploded View it
                            you have your grooves! πŸ’š
                            https://i.postimg.cc/BbJx0qzz/CadRays2.jpg
                            • V Offline
                              vbbartlett
                              I have a file that breaks, I am attaching it in hopes that you can use it to improve the plugin, which is awesome btw. It is a tooth of a gear. I have removed the rest of the gear as it is just too many verts.
                              fredoerror.skp
                              • fredo6F Offline
                                fredo6
                                I think you should first eliminate the very small edge to make it work.
                                Currently the limitation is that the offset should be smaller that the shortest edge in the selection. This is true for RoundCorner and FredoCorner.
                                • fredo6F Offline
                                  fredo6
                                  NEW RELEASE: FredoCorner v2.1a - 19 Nov 20
                                  Requirement: LibFredo6 11.3a
                                  FredoCorner 2.1a is a maintenance release
                                  • Bug fixing for Orbit/Pan on Windows for Preview mode
                                  • fredo6F Offline
                                    fredo6
                                    NEW RELEASE: FredoCorner v2.1b - 02 Dec 20
                                    FredoCorner 2.1b is a maintenance release
                                    • Prevent to set the number of segments to 0
                                    • fredo6F Offline
                                      fredo6
                                      NEW RELEASE: FredoCorner v2.2a - 06 Jan 21
                                      FredoCorner 2.2a is a maintenance release for extension of validity
                                      • fredo6F Offline
                                        fredo6
                                        Requirement: LibFredo6 11.6a
                                        Requirement: Sketchuchucation ExtensionStore 4.0.0.e
                                        FredoCorner v2.3a becomes a paid plugin.
                                        There is a Free trial period of 15 days from activation, with full features. Then, you need to license the extension on Sketchucation:
                                        • Perpetual License (3 seats): 22 €
                                        • Rush License (21 days from purchase date, 3 seats): 7 €
                                          See this post for instructions to license an extension on Sketchucation.
                                        Note: the previous version v2.2a will naturally expires on 31 Jan 21
                                        • H Offline
                                          HarryR
                                          I would love to buy the [Plugin][$] FredoCorner - v2.3a - 27 Jan 21. However, I am completely lost in where to go to purchase it. Could you please put a link to click that will bring me to the purchase page. I reckon it would have a massive impact on your sales because most people do not have time to follow the hints to where it might be. Brilliant plugin, but please help me to buy it!
                                          • fredo6F Offline
                                            fredo6
                                            Just download and install FredoCorner normally (along with LibFredo6 v11.6).
                                            You get a free trial period of 15 days.
                                            If you wish to license it (before or at expiration of free trial period), go to the menu of FredoCorner, which is at Tools > Fredo6 Collection > FredoCorner > License....
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 22
                                            • 23
                                            • 10 / 23
