    Spaciship? Spaciship!
    109 Posts 12 Posters 82.9k Views 12 Watching
      Like a butterfly coming out of a cocoon, pretty much describes the creation of any model. Getting there dood.
        For some inspiration Space Ships! πŸ˜‰ (made with SU)
        By Karanak (Scroll down)
        and a some detailed making of (with SU)! πŸ€“
        • Bryan KB Offline
          From here on I am going take each major mass block and detail them as new, separate files and then import them back as components.
          This is easily done by copying the block I want to work on, opening a new file and then "Paste in Place". When they are imported back into the main drawing, they slot back exactly in the location they were copied from if they were not moved away from the origin point in the new file. When you import, be sure to use the origin point to place the imported component. (where all three axis meet)
          • Bryan KB Offline
            I'll start back at the beginning with the bridge.
            The first picture shows the relationship to copy and paste in place in new file. The second one shows the comparison updates.
            • Bryan KB Offline
              Starboard side.
              • Bryan KB Offline
                Close up.
                • Bryan KB Offline
                  Aft view
                  • tuna1957T Offline
                    tuna1957
                    Looking better all the time Bryan. Keep up the great work πŸ‘ .
                    • Bryan KB Offline
                      Thanks tuna.
                      Here is the bridge imported back into the main model and two more smaller mass blocks detailed and added.
                      • Bryan KB Offline
                        Busy week at work. I'll post updates tomorrow.
                        • Bryan KB Offline
                          Greeble panel as drawn by the artist.
                          • Bryan KB Offline
                            Greeble panel placed back into model. Look close and just barely make out SketchUp person.
                            • Bryan KB Offline
                              Tranport hanger doors.
                              I'm using very simple angles and push/pull offsets.
                              • Bryan KB Offline
                                I forgot the close up of the guns. Again very simple trapezoids. Everything will get more detail over time, but not too much. The ship is so large that details too small are not worth modeling after a certain point.
                                • Bryan KB Offline
                                  Here is the bow detail. The gun was just turned upside down and push/pull used for equipment bay thing and simple arches and offsets for detail.
                                  • Bryan KB Offline
                                    Here is how it's all fitting together so far. I may start work on the aft sections next.
                                    • Bryan KB Offline
                                      Modified module imported back into model.
                                      All non-detailed mass blocks are erased just before importing the modified mass block. Do not erase before. You might need it again until the detail is finished.
                                      • Bryan KB Offline
                                        Roughed out angular modifications along the keel. Very long way to go underneath.
                                        • Bryan KB Offline
                                          Couldn't resist posting another shot. Changed the shadow angle.
                                          • HornOxxH Offline
                                            HornOxx
                                            πŸ‘ πŸ‘ your first picture of this post compared to this last one - Wow !!
                                            keep spaceshiping !! πŸ˜„
                                            never trust a skinny cook
                                            • 6
                                            • 2 / 6
