    Spaciship? Spaciship!
    109 Posts 12 Posters 93.8k Views 12 Watching
    • Bryan KB
      From here on it's going to be detail work. I'll try to post logical updates, but I'm not sure how well everyone will be able to follow along.
      • Bryan KB
        More details.
          Like a butterfly coming out of a cocoon, pretty much describes the creation of any model. Getting there dood.
            For some inspiration Space Ships! πŸ˜‰ (made with SU)
            By Karanak (Scroll down)
            and a some detailed making of (with SU)! πŸ€“
            • Bryan KB
              From here on I am going take each major mass block and detail them as new, separate files and then import them back as components.
              This is easily done by copying the block I want to work on, opening a new file and then "Paste in Place". When they are imported back into the main drawing, they slot back exactly in the location they were copied from if they were not moved away from the origin point in the new file. When you import, be sure to use the origin point to place the imported component. (where all three axis meet)
              • Bryan KB
                I'll start back at the beginning with the bridge.
                The first picture shows the relationship to copy and paste in place in new file. The second one shows the comparison updates.
                • Bryan KB
                  Starboard side.
                  • Bryan KB
                    Close up.
                    • Bryan KB
                      Aft view
                      • tuna1957T
                        tuna1957
                        Looking better all the time Bryan. Keep up the great work πŸ‘ .
                        • Bryan KB
                          Thanks tuna.
                          Here is the bridge imported back into the main model and two more smaller mass blocks detailed and added.
                          • Bryan KB
                            Busy week at work. I'll post updates tomorrow.
                            • Bryan KB
                              Greeble panel as drawn by the artist.
                              • Bryan KB
                                Greeble panel placed back into model. Look close and just barely make out SketchUp person.
                                • Bryan KB
                                  Tranport hanger doors.
                                  I'm using very simple angles and push/pull offsets.
                                  • Bryan KB
                                    I forgot the close up of the guns. Again very simple trapezoids. Everything will get more detail over time, but not too much. The ship is so large that details too small are not worth modeling after a certain point.
                                    • Bryan KB
                                      Here is the bow detail. The gun was just turned upside down and push/pull used for equipment bay thing and simple arches and offsets for detail.
                                      • Bryan KB
                                        Here is how it's all fitting together so far. I may start work on the aft sections next.
                                        • Bryan KB
                                          Modified module imported back into model.
                                          All non-detailed mass blocks are erased just before importing the modified mass block. Do not erase before. You might need it again until the detail is finished.
                                          • Bryan KB
                                            Roughed out angular modifications along the keel. Very long way to go underneath.
                                            • 2 / 6
