    Spaciship? Spaciship!
    109 Posts 12 Posters 91.3k Views 12 Watching
    • Bryan KB Offline
      Most of the large massing is now complete. Some proportions and shapes still need adjusting, but it's pretty close as is.
      • Bryan KB Offline
        Starting some detail and smaller mass blocks
        • Bryan KB Offline
          From here on it's going to be detail work. I'll try to post logical updates, but I'm not sure how well everyone will be able to follow along.
          • Bryan KB Offline
            More details.
              Like a butterfly coming out of a cocoon, pretty much describes the creation of any model. Getting there dood.
                For some inspiration Space Ships! πŸ˜‰ (made with SU)
                By Karanak (Scroll down)
                and a some detailed making of (with SU)! πŸ€“
                • Bryan KB Offline
                  From here on I am going take each major mass block and detail them as new, separate files and then import them back as components.
                  This is easily done by copying the block I want to work on, opening a new file and then "Paste in Place". When they are imported back into the main drawing, they slot back exactly in the location they were copied from if they were not moved away from the origin point in the new file. When you import, be sure to use the origin point to place the imported component. (where all three axis meet)
                  • Bryan KB Offline
                    I'll start back at the beginning with the bridge.
                    The first picture shows the relationship to copy and paste in place in new file. The second one shows the comparison updates.
                    • Bryan KB Offline
                      Starboard side.
                      • Bryan KB Offline
                        Close up.
                        • Bryan KB Offline
                          Aft view
                          • tuna1957T Offline
                            tuna1957
                            Looking better all the time Bryan. Keep up the great work πŸ‘ .
                            • Bryan KB Offline
                              Thanks tuna.
                              Here is the bridge imported back into the main model and two more smaller mass blocks detailed and added.
                              • Bryan KB Offline
                                Busy week at work. I'll post updates tomorrow.
                                • Bryan KB Offline
                                  Greeble panel as drawn by the artist.
                                  • Bryan KB Offline
                                    Greeble panel placed back into model. Look close and just barely make out SketchUp person.
                                    • Bryan KB Offline
                                      Tranport hanger doors.
                                      I'm using very simple angles and push/pull offsets.
                                      • Bryan KB Offline
                                        I forgot the close up of the guns. Again very simple trapezoids. Everything will get more detail over time, but not too much. The ship is so large that details too small are not worth modeling after a certain point.
                                        • Bryan KB Offline
                                          Here is the bow detail. The gun was just turned upside down and push/pull used for equipment bay thing and simple arches and offsets for detail.
                                          • Bryan KB Offline
                                            Here is how it's all fitting together so far. I may start work on the aft sections next.
                                            • 2 / 6
