π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
Vray 3.6 GPU rendering black out issue
Hi all!!
Im currently rendering a interior scene with GPU + CPU, everything works fine but some component becomes black, however when i render with CPU only the issue is fixed.
My component has nothing complex, only a texture map material, nothing else.
Does anybody know how i can fix this issue??
Thankyou very much!~!
Can you post some screenshots?
Make sure those components doesn't have backfaces visible to camera. (Check in monochrome mode)
Do you have the latest GPU driver installed?
