    SU Pro 2018 Hardware Acceleration Problem
    3 Posts 2 Posters 10.3k Views 2 Watching
    • Bob JamesB
      Bob James
      I am using a Nvidia 1080ti GPU Driver Version 391.35
      When I try to open SU, I get this error:
      Hardware acceleration is activated:
      • TIGT
        SketchUp uses OpenGL.
        I'd expect your Graphics Card to have > v3.?
        Ensure that its drivers are up to date, and it is enabled for SketchUp etc...
        Use your NVIDIA Control Panel and set it to 'Let the 3d application decide'...
        SketchUp should auto-configure itself...
        Under its 'Manage 3d Settings'...
        == Trimble SketchUp
        Either accept all of the default settings, or consider removing it from the list if it's still being awkward...
        • Bob JamesB
          Bob James
          Thank you a TONfor your help. As you can see below I have a couple of questions.
          This all started when I updated the drivers.
          OpenGL v4.5
          Version 391.35 is the latest
          Do you mean that Trimble SketchUp is in the Manage 3d Settings list?
          Let the 3d application decide what? OpenGL? Hardware Acceleration?
          %(#FF0000)[Good 😎]
          == Trimble SketchUp
          This has all of the default settings since I did not go into NVidia Control Panel/3D Settings/Manage 3D Settings to change any of the 21 settings
