    How to rotate texture without scaling it
    11 Posts 7 Posters 5.7k Views 7 Watching
    • M
      Mikar
      Hi all,
      whenever I try to rotate a texture with the texture-->position-->green-handle-thingy the texture starts scaling at the same time. Is there a way to rotate only (e.g. by pressing a key or keyboard entry) so that it doesn't rotate and scale at the same time?
      Cheers
      Mikar
      • R
        rv1974
        The most effective way:
        Eneroth Texture Positioning-
        Align texture to edge
          @mikar said:
          Hi all,
          Cheers
          Mikar
          It doesn't have to scale as it is rotated. No plugin/extension needed. Pay attention to where the handle goes. As you drag it, there's an arc following from the starting location. Keep the cursor on that arc or bring it back to the endpoint of the arc to keep the same scale. If you are rotating a texture either 90°, 180°, or 270°, right click on the texture again and choose Rotate and then the angle.
          Click on the picture
          • boofredlayB
            boofredlay
            @dave r said:
            It doesn't have to scale as it is rotated. No plugin/extension needed. Pay attention to where the handle goes. As you drag it, there's an arc following from the starting location. Keep the cursor on that arc or bring it back to the endpoint of the arc to keep the same scale...
            And here is a picture showing what Dave is talking about. This will keep the texture at the original scale.
              Thanks Eric. Mine is an animated GIF showing that.
              • boofredlayB
                boofredlay
                😳 I did not see your note "click on the picture".
                • M
                  Mikar
                  Great tips (an so much effort put into explaining)! Thank you all very much!
                  Cheers
                  Mikar
                  • Joe WoodJ
                    Joe Wood
                    Thanks Dave! I never knew you could r click again and choose 90*! That'll be very handy!
                    Joe Wood
                    woodsshop.com/
                    • V
                      valerostudio
                      This plugin is one of my favorites - use it about 100 times a day - get it! You can set rotate 90 to a keyboard shortcut. Useful when working on millwork.
                      • R
                        rv1974
                        True..
                        Compare this tool with standard messy tool. This plugin/extension IS needed
                        • HornOxxH
                          HornOxx
                          again a D'oh!- moment for me and I join in these thanks 👍 😄
                          never trust a skinny cook
