    Vray3.6 displacement problem ... help!
    renderpluginsextensions
    5 Posts 5 Posters 6.6k Views 5 Watching
      cuttingedge
      I have a strange behavior of displacement map in vray 3.6.
      I cant make it to work. The material preview shows a good displacement but it doesnt appear in the render.Tried and tried but cant make it work.
      vray 3.6 displacement problem
      Even I tried models done in vray 2.0 which worked but wont work in 3.6.
      Anyone having the same issue? below is the displacement map
      displacement map
      • E Offline
        EpsiOne
        Same problem for me. Anyone?
          syege
          just found the solution, u gotta apply the material from within the vray material list... u know select your geometry, go to vray asset editor material list select your material, right click apply to selection and BUMP! i mean displacement eheh
            muthenna75
            Hello
            I have the same problem with V ray 3.6
            • V Offline
              valerostudio
              Use fur for carpets man! - displacement is not worth it. Fur is 1000X faster and better for this application. I try to stay away from displacement altogether honestly.
              If you must - like you said above, the material needs to applied directly to the faces (not to the group).
              Displacement on the left, fur on the right
