Vray3.6 displacement problem ... help!
I have a strange behavior of displacement map in vray 3.6.
I cant make it to work. The material preview shows a good displacement but it doesnt appear in the render.Tried and tried but cant make it work.
Even I tried models done in vray 2.0 which worked but wont work in 3.6.
Anyone having the same issue? below is the displacement map
Same problem for me. Anyone?
just found the solution, u gotta apply the material from within the vray material list... u know select your geometry, go to vray asset editor material list select your material, right click apply to selection and BUMP! i mean displacement eheh
Hello
I have the same problem with V ray 3.6 -
Use fur for carpets man! - displacement is not worth it. Fur is 1000X faster and better for this application. I try to stay away from displacement altogether honestly.
If you must - like you said above, the material needs to applied directly to the faces (not to the group).
Displacement on the left, fur on the right
