    Smooth contour lines plugin
    5 Posts 4 Posters 3.1k Views 4 Watching
      ArtPen
      Hi Guys,
      Just wondering if there is a plugin / extension which will smooth all contour lines I have got from slicing terrain (with planes).
      I am getting something like on image 01 and I want to get a smooth poly line Image 02, I know it will create more points.
      Or maybe convert to B-Spline using points as a control points for a spline?
      Thank you,
      Image 01
      Image 02
        Use TIG Weld to weld the edges of each contour together and then convert the contours to Catmull Splines with Fredo's BZ_Spline extension.
        • fredo6F Offline
          fredo6
          I would rather use Curvizard, which has a bulk mode to operate on all curves in one-shot and can both smooth and weld at the same time.
            ArtPen
            Thank you it is what I need! Curvizard works perfectly.
            Do you know if there is a way to project a 2d road, but then make it flat ?
            Instant Road NUI alternative?
            Cheers
            • pbacotP Offline
              Excellent suggestions. I have to look into that use of Curvizard.
              Road depends on the terrain and the extent. Why not build the road if you want it flat? You can push pull a projection down to the terrain then give the road the grade that you want. Keep it separate from the terrain Reshape a copy of the existing terrain (new terrain) for fill and cut around the road. Sometimes I project the road on a copy of the terrain with sandbox Drape. I don't like to cut up the terrain with Drape directly. Makes a mess. Depends on what you are starting with in terms of topo and what your end use is (e.g. how accurate). Sometimes a simple drape is enough to indicate a road for the views you are making. Sometimes you are working out a design for an actual road.
