    Knowledgeable stair builders, what is this called?
    8 Posts 6 Posters 2.3k Views 6 Watching
      CalypsoArt
      Knowledgeable architects or stair builders. What is this called? I've looked in all my resources. I can find no name. I went with Reverse Finial.
        It's on the bottom of a newel post: so include that in its name.
        That newel is also extended downwards [aka dropped?]: so perhaps somehow include that in its name.
        It's also a cap [or finial]: so include that in its name.
        I'd call it a "dropped-newel-with-cap" [or "...[-bottom]-finial"]
        [at least in UK-England]
        Different locales will probably have different naming conventions...
        Draw it and explain in words.
        The builder/joiner should understand you...
          Remember that a simple 'dropped-newel' might not have any 'cap' at all [perhaps just chamfers to its exposed edges], so for-the-avoidance-of-doubt I'd add something like '...-with-cap' [or '-finial' etc] if it has one...
          • S ShepherdS Offline
            S Shepherd
            I think I'd go with Dropped Newel.
            [Edit] Also pendant might be applicable
            S.
              rtd
              Are you creating design or construction documents?
              I assume that there would be a drawing of it at a suitable scale to establish the profile desired. I'd go with 'dropped newel, see detail'.
              • pmolsonP Offline
                pmolson
                Thingamajig
                πŸ˜„
                • boofredlayB Offline
                  boofredlay
                  You could describe it as a dropped or lowered newel post. I have seen it as just a newel post with lower post cap. And if it has a cap at the top then call that out too.
                  Although Ron describes them as "dropped" on this blog post:
                  http://stairman.blogspot.com/2015/02/historic-fraternity-house-reproduction.html
                  Here it is referred to as a newel drop.
                  http://site.stairwarehouse.com/Post-to-post.gif
                    CalypsoArt
                    Thanks all. I'm going with Dropped newel and reverse finial.
