    'Sticky' Material Library - Cyber-Material-Collection
    3 Posts 2 Posters 786 Views 2 Watching
      MichaelSiggers
      Good Evening
      Firstly please let me know if I've posted this in the wrong section.
      A couple of weeks ago, I purchased a Materials 'Pack', on Cyber Monday. It was the 'cyber-material-collection'. I didn't get a chance to use it straight away as I was away.
      Anyway, I have found a problem with two of the libraries within the set, namely the 'Weave' and 'Fabric' sets.
      Essentially, within these two sets, when I select a material and apply it, it will not then allow me to select a different material from the set to use. It always applies the first one I selected, no matter which other one I try to select.
      This only happens within these two sets.
      I found a thread on the Sketchup forum and posted my query there, as someone else has experienced the same issue before. Through that discussion, I was advised to post here and let Rich know of the problem. Unfortunately I do not know who Rich is, so maybe someone can point me in the right direction.
      Anyway, for information, I am running both Sketchup pro 2017 and 2018, on a later 2014 iMac, with 16GB of RAM, and 2GB GPU.
      As mentioned above, ALL the other materials/textures in the other sets work perfectly, (Tile, Old Brick, Industrial Metal etc.).
      Hoping someone can help, or advise who I should be contacting.
      Many thanks in advance.
      Kind regards
      Mike
        What rendering plugin are you running?
        email me at richob@sketchucation.com and we fix it πŸ‘
          MichaelSiggers
          Hi Rich
          I use Thea.
          I'm not too worried. I've just deleted those two sets.
          Just bought and downloaded the 'Cyber Monday' Set as well, and the same problem occurs with the 'Wood' Set in that.
          Kind regards
          Mike
