    BUG
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    7 Posts 2 Posters 7.4k Views 2 Watching
    • X Offline
      xufeng
      I'm using sketch up 2015,after i creat a movement about path ,i want to modify, nothing can be done.
      • fredo6F Offline
        fredo6
        Could you open the Ruby console and advise on error messages
        Fredo
        • X Offline
          xufeng
          Fredo
          Error: #<NoMethodError: undefined method each' for nil:NilClass> c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/body_lib6pathmanager.rbs:2022:in compute_shadow_for_display'
          c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/body_lib6pathmanager.rbs:2007:in compute_shadow' c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/body_lib6pathmanager.rbs:1993:in compute_info'
          c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/body_lib6pathmanager.rbs:2131:in locate_point' c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/body_lib6pathmanager.rbs:2201:in handle_move'
          c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/body_lib6deepmover.rbs:1734:in handle_move' c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_animator/animatoreditoraamixin.rbs:1002:in handle_move'
          c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_animator/animatortool.rbs:977:in onMouseMove' c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_animator/animatortool.rbs:937:in onMouseMove_zero'
          c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_animator/animatortool.rbs:1157:in `onLButtonUp'
          • fredo6F Offline
            fredo6
            Could you post your model so that I have a look.
            Fredo
            • X Offline
              xufeng
              Fredo
              I just make a cuboid and group it ,next, I draw a line to regard as path ,that's so simple,but nothing can be done in animator .
              • X Offline
                xufeng
                @xufeng said:
                Fredo
                1.skp
                • fredo6F Offline
                  fredo6
                  @xufeng,
                  Can you check you run the latest version of Animator and LibFredo6. I tested on SU2015 (as it seems to be your version) and found no problem.
                  Fredo
                  Xufeng - path1 - SU2015.skp
                  Xufeng Follow path.mov
