BUG
I'm using sketch up 2015,after i creat a movement about path ,i want to modify, nothing can be done.
Could you open the Ruby console and advise on error messages
Error: #<NoMethodError: undefined method
each' for nil:NilClass> c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/body_lib6pathmanager.rbs:2022:incompute_shadow_for_display'
c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/body_lib6pathmanager.rbs:2007:incompute_shadow' c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/body_lib6pathmanager.rbs:1993:incompute_info'
c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/body_lib6pathmanager.rbs:2131:inlocate_point' c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/body_lib6pathmanager.rbs:2201:inhandle_move'
c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/body_lib6deepmover.rbs:1734:inhandle_move' c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_animator/animatoreditoraamixin.rbs:1002:inhandle_move'
c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_animator/animatortool.rbs:977:inonMouseMove' c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_animator/animatortool.rbs:937:inonMouseMove_zero'
c:/users/123/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/fredo6_animator/animatortool.rbs:1157:in `onLButtonUp' -
Could you post your model so that I have a look.
I just make a cuboid and group it ,next, I draw a line to regard as path ,that's so simple,but nothing can be done in animator .
Can you check you run the latest version of Animator and LibFredo6. I tested on SU2015 (as it seems to be your version) and found no problem.
