    Move Tool
    3 Posts 3 Posters 875 Views 3 Watching
    • A
      atticfour
      I am learning how to use SKETCHUP.
      I am unable to move a component of a model up and down.
      It's the up - down axis, I believe.
      Need help.
      Thanks in advance.
      Ted
      • BepB
        Bep
        "History is written by the winners"
        • TIGT
          If the [imported] component has gluing/cutting behavior set, then that means any instance of it will "stick" it onto the first face you applied it onto.
          If you select such an instance, right-click > context > unglue...
          It can then be moved independently of its initial connected face...
