    Shape bender plane problem
    2 Posts 2 Posters 617 Views 2 Watching
      dohyungkim
      I did shape bender flat one to curved one behind in the image
      I don't know Why I got that diagonol lines in the red circle.
      Can anyone tell me how to do shapebender without that line???
      by the way I couldn't delete that line without losing plane....
        It's because the bending skewed that particular surface, so to retain it a diagonal was added.
        The two triangular facets are no longer coplanar, so you can't simply delete that shared edge.
        You can use Erase + Ctrl to smooth it.
        If you use View > Hidden Geometry > ON you'll see various added smoothed edges in the bent form.
        Somehow that one slipped through.
        So just 'smooth' it, and carry on...
