    Light température in VRay 3.4
    renderpluginsextensions
    6 Posts 4 Posters 3.7k Views 4 Watching
      sakuraya
      Hello. I have a problème I can't find the temperature setting in lights I use a Plane Light.
      Someone can help me?
      Thank you very much
      • filibisF Offline
        filibis
        I'm not expert on this but temperature of a light is simply a color, right? And i think there is no temperature parameter in Vray for SketchUp ( Vray for Maya has though ).
        So just pick a color.
        If you want presize Kelvin values to be repsented with RGB or hex values, check this chart:
        http://www.vendian.org/mncharity/dir3/blackbody/UnstableURLs/bbr_color.html
        Hyperlinks messes up for some reason so here are references:
        https://docs.chaosgroup.com/display/VRAYSKETCHUP/V-Ray+Rectangle+Light+or+Plane+Light+%7C+LightRectangle
        https://docs.chaosgroup.com/display/VRAY3MAYA/Temperature+Color+Map+%7C+VRayTemperature
          sakuraya
          Hello, yes it's white or yellow color. I will try to add color.
          Thank you for you help.
          Cyrille
            sakuraya
            It works perfectly.
            Thank you very much
              archmbai
              Hello. I am new and needed some help. Don't know how to start a new thread but my problem is a V-ray error. V-ray had been working fine till last night. Gives me a JavaScript uncaught exception error each time I'm trying to render. Gets to 86% on compiling geometry then the screen goes black and exits. Anyone with an idea of how to help? Trying to get pictures to further explain the problem 😕
                burlynomad
                Hey Laurent, This is definitely a problem you'll want to email support@chaosgroup.com and tell them about. They are very responsive and will be able to sort this out for you.
