    FlexWindow FT 2.5: sticky component behaviour
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    2 Posts 2 Posters 7.9k Views 2 Watching
    • O Offline
      optimaforever
      Hi Yoni and devs,
      1. I see that the new FlexWindow is sticky by default.
        While this is often handy and I understand the advantage, sometimes it's annoying to have the FlexWindow stick to the ground when you want to create a vertical curtainglass (which by principle doesn't cut a wall, being the wall itself).
      EDIT: sorry, I hadn't seen the toggle cutter button... 💚
      1. I can't create presets (favourites?) from my existing FlexWindow/doors/slats (grayed add favs icon). I guess this mean ùy components are not compatible with the new Flex definition standards?
      • halroachH Offline
        halroach
        1. It's sticky be default, in order to give you nice flat icons in the favorites window. (I know that may sound rediculous 😄)
          If you have the 90* rotator on (in the manager window) it won't be sticky.
        2. That will be a bit difficult right now. Best if you recreate your presets/favorites.
        FlexTools - Super Quick Windows, Doors, Slats...
