    Fredo6: Joint Push Pull Interactive v3.6a issue
    5 Posts 3 Posters 1.2k Views 3 Watching
      SWills
      Hi guys,
      I just downloaded the Fredo6: Joint Push Pull Interactive v3.6aplugin but am having issues with using the round push pull tool. When I try to appy the change, nothing happens and a red window comes up on my screen that says "An error occurred in Round Push Pull Error in generation of the geometry undefined method `[' for nil:NilClass".]What can I do to fix this?
      https://s-media-cache-ak0.pinimg.com/564x/8b/69/b5/8b69b53164695085bd8b4b9a1c64147c.jpg
      • fredo6F Offline
        fredo6
        @swills said:
        Hi guys,
        The best is to attach the skp model, and also paste a text copy of the error message (which indicates which line of code is faulty).
        Fredo
          @SWills
          Please upload a SKP displaying this issue.
          It need not be a big file, just the part with the problem...
            SWills
            Just updated the post!
            Thank you
            • fredo6F Offline
              fredo6
              @SWills
              Thanks for the log.
              RoundPushPull is not really designed for this type of surface. It is more for boxy shapes.
              You should use JointPushPull instead, if it is just to thicken the surface.
              Fredo
