    Spiral Doric Column
    15 Posts 8 Posters 13.2k Views 8 Watching
    • chippwaltersC Offline
      chippwalters
      A quick video on how I use some of my favorite Fredo (and others) plugins to create a simple spiral doric column.
      Plugins used:
      FredoScale
      Curviloft
      CleanUp
      Set Center Point
      Ambient Occlusion
      FDD
      Currently working with Cross-Reality technologies
      • HornOxxH Offline
        HornOxx
        ๐Ÿ‘ x 5
        Impossible to give 5 thumbs up by simply clicking them ๐Ÿ˜„ so I give them this way!
        many thanks for this most helpful tutorial !
        btw: so finally I rediscovered my FDD plugin within my context menu ๐Ÿ˜„
        never trust a skinny cook
        • N Offline
          nlipovac
          Great tutorial Chipp!
          Thank you. ๐Ÿ˜„
          • BoxB Offline
            Just like to point out that the default for Move is M, not T.
            And you don't need to use ctrl with follow me.
              rv1974
              Chipp you're perfect educator. Keep them coming!
                chippwalters
                I set my default to T so it will match some of my other programs. Thanks for the tip on follow me...I seem to remember in previous versions you had to press the CTRL key in order for Follow-Me to work if you previously had selected the path.
                • BoxB Offline
                  I only mentioned the M versus T for users who may be watching your tutorial. T will bring up the tape measure by default and I can see beginners getting confused.
                  • HornOxxH Offline
                    HornOxx
                    @jim4366 said:
                    ...where to get the "set center point" tool?...
                    Hi, here you can find it:
                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=11081
                    It will add the entry "Add Centerpoint" in the Extensionยดs menu (no icon bar)
                    • david_hD Offline
                      david_h
                      Fun little study. I have actually had all of these plugins in my arsenal for years, but sometimes you just forget to use em. Thanks for the tut.
                      • pbacotP Offline
                        Nice job. Thanks for the line up on plugins! The other day just tried doing a basic tuscsan column (not the first time)and entasis by brute force. I should have used FFD.
                          CAUL
                          It's actually quite straight forward to construct a "canonical" entasis in Sketchup for any type of column - smooth or fluted. Canonical here means the recipe engraved in a wall at the temple of Apollo at Didyma (Turkey) some 2500 years ago. The method below is not exactly as described at the Temple of Apollo, but it's very, very close in practice.
                          Set out an arc with the Pie tool (as in the first image below). Scale this arc all the way to the top. The resulting elliptical curve is the shape of the entasis. The shaft is usually straight the first third of the height and the entasis is only applied to the top two thirds.
                          To construct an entasis on a fluted column it's possible to use Flowify twice. From the entasis curve, construct a quaded target surface. Construct a projection surface with the full width of the shaft and every quad with the exact same height as the corresponding quad on the target surface.
                          Connect and group the surfaces into a Flowify support group. Make a copy of the group and rotate it 90 degrees and place it as in the second image below. Flowify a fluted column through the first support group. Flowify the result through the second support group. The entasis is now applied to both the x and y-dimension. Merge the entasis part into the full column.
                            rv1974
                            Much closer to original ๐Ÿ‘
                              chippwalters
                              @caul said:
                              It's actually quite straight forward to construct a "canonical" entasis in Sketchup for any type of column - smooth or fluted. <snip>
                              I've done two different tutorials on Flowify and even I had a hard time following this, but it is an ingenious use of the tool!
                              • BoxB Offline
                                Do mine eyes deceive me or is there no spiral.
                                  CAUL
                                  I've added a highly exaggerated example file to show the basic principle.
                                  entasis(skp8).zip
