    How do I import visopt to Vray 3.4?
    renderpluginsextensions
    4 Posts 4 Posters 29.8k Views 4 Watching
      ciarle_
      Hello,
      Can anybody tell me how to import Visopt to Vray 3.4? I knew how to do it when I had the older version of Vray but I can't find it now.
      Thank you
      • V Offline
        valerostudio
        3.4 has been rebuilt from the ground up. I dont think old vispot would work, even if you could import them.
          jgabiel
          This new format suported on Vray 3.4 is .vropt, change the extension of .vispot for .vropt and try import again!
          • filibisF Offline
            filibis
            According to official Vray Docs.: Migrating from Previous Versions
            Loading ‘.vropt’ or ‘.visopt’ files created in previous V-Ray versions is not recommended. Some outdated parameters may cause unexpected results. Using the new streamlined quality presets, and then fine-tuning the settings before saving them in a new ‘.vropt’ file is the recommended approach.
