    Noise from the lights on the floor
    renderpluginsextensions
    6 Posts 4 Posters 1.5k Views 4 Watching
      shayar mbn
      Hey guys
      I'm using vray 3.4, and rendering an interior scene and using Emissive color for lighting bulbs on ceiling and there is a strong noise on the floor. does anyone know how i can solve this issue?
      • kimi kimiK Offline
        kimi kimi
        Emissive is known to produce noise. Since mesh light is introduced in new V-Ray, try using that instead of emissive layer.
        • filibisF Offline
          filibis
          Try not to lit your scene only with emissive material. It's intended to give the effect of TV screen, fireplace etc. (with the use of texture) but not lighten the room itself. So use Mesh Light as kimi kimi suggested.
            shayar mbn
            thank you very much kimi kimi, problem solved.
              shayar mbn
              great! I used mesh light and it solved the problem! thank you!
                tomo1911
                I have the progressive render to be noisy. and choose to bucket render over progressive, more like vray 2 for me now.
