    Saved files not showing as "skp" in Make 2017
    4 Posts 3 Posters 881 Views 3 Watching
    • McGyverM Offline
      McGyver
      This is a minor annoyance, but I've installed Make 2017 on my daughter's computer (Windows 7 pro) and when she saves a file it omits the "skp" extension.
      If she names it "Garden_Bench-01" it leaves out the .skp instead of naming it "Garden_Bench-01.skp".
      But for some reason it does not omit the "skb" in an skb save...
      I checked preferences, but there is no option for that.
      Is this a weird little bug, or is this a Windows 7 issue?
      I'm using SU 2016 on my computer, which is also Windows 7 pro and this does not occur.
      Weird.
      Thanks in advance if you have any input.
      Visit My ShareCG Freebie Gallery
        Make sure that you have installed SketchUp properly.
        The [only] correct way is to close SketchUp, then find its installer's exe file [probably in your Downloads folder or maybe where you placed the exe later?]
        Then right-click > context-menu > "Run as administrator..."
        When prompted, choose to "Repair"...
        This will ensure SketchUp is properly installed.
          Is her computer setup to show file extensions for known file types?
          • McGyverM Offline
            McGyver
            That's exactly what I was looking for.
            I thought it was a SketchUp setting.
            I'm an ex Mac user, and sometimes those common Windows functions don't click.
            I didn't think to check folder options in the "view" section.
            Thanks DaveR and TIG!
