    Looking for square tube plugin...for closed path
    3 Posts 2 Posters 2.1k Views 2 Watching
    • D
      dohyungkim
      Hello Sketchup gurus....
      I need help ㅜ.ㅜ
      I need square tube along path plugin.... (I named it instantly)
      here's my image url
      404 Not Found
      (www.imageupload.co.uk)
      no.1 is my base lines (closed path)
      no.2 made out of lines to tube by D.bur (precision 4) but its
      corners are not right and..I want its top/bottom surfaces be parallel to the floor
      not like diamond ♦ but square □
      no.3 is what i'm looking for but I did other way to make that.
      I want to use some square tube plugin on no.1 and get no.3.
      no.4 is sphere wireframe + lines to tube plugin
      the peoblem of pipe along path and extrude along path is that they don't work
      on 'closed path'. they pick random lines and turn out to some weird stuff
      no.5 I need some plugin that can get me the last model(right bottom) from no.5
      I have lines to tube/ pipe along path / extrude along path
      none of'em got me what I'm looking for
      is there any plugin which can make 'square' tube on closed path?
      • TIGT
        Look at this:
        https://sketchucation.com/pluginstore?pln=ene_uprightExtruder_v1.2.0
        • D
          dohyungkim
          Thanx for reply famous TIG.
          I'm newbie but at least I know you are plugin God.
          I just tested upright extruder and found it's very useful tool!
          thanx again!
          but also do you know any 'square tube' plugin works like 'lines to tube' by D.bur?
          I just need exact same like 'lines to tube' function but generate 'square tube'
          instead of circular tube.
