    Delete a list of components by their definitions.
    24 Posts 5 Posters 5.2k Views 5 Watching
    • TNTDAVIDT Offline
      TNTDAVID
      **Hello, ☀
      I want to delete a list of components with their definitions and then purge their textures.
      Description of the step-by-step method:
      1 - All components that are named ['BOXE', 'CUBE'] in their definitions are deleted and purged without affecting the unused components.
      2 - All textures used by the components in the list must be purged without affecting the other materials.
      Note
      The goal is to find an alternative to purge_unused.
      The method must remove the components even if they are used in SketchUp and nested within groups.
      Any help in writing this method will be of great help to me.
      Thank you
      David**
        Construct a 'match' regexp to suit - e.g. match=/BOX/
        It's been explained before how to limit that to matches starting with BOX etc /^BOX/ and trap for upper/lowercase characters...
        Assemble an array of definitions, using that 'match' filter [untested!].
        model=Sketchup.active_model
        # collect matching definitions
        defstogo=model.definitions.find_all{|d| d.name =~ match }
        # collect materials.
        matstogo=[]
        defstogo.each{|d|
          # first used by instances
          d.instances.each{|i|
            matstogo << i.material unless matstogo.include?(i.material)
          # now used by its entities
          d.entities.each{|e|
            matstogo << e.material unless matstogo.include?(e.material)
            ( matstogo << e.back_material unless matstogo.include?(e.material) ) if e.is_a?(Sketchup;;Face)
        matstogo.compact!
        matstogo.uniq!
        # now check if materials used elsewhere
        defsNOTtogo=model.definitions.find_all{|d| ! d.name =~ match }
        matsNOYtogo=[]
        defsNOTtogo.each{|d|
            matsNOTtogo << i.material unless matsNOTtogo.include?(i.material)
          d.entities.each{|e|
            matsNOTtogo << e.material unless matsNOTtogo.include?(e.material)
            ( matsNOTtogo << e.back_material unless matsNOTtogo.include?(e.material) ) if e.is_a?(Sketchup;;Face)
        matsNOTtogo.compact!
        matsNOTtogo.uniq!
        # now reduce matstogo as necessary...
        matstogo.clone.each{|e|
          matstogo.delete(e) if matsNOTtogo.include?(e)
        # start and operation ro ensure Garbage Collection works...
        model.start_operation('Purger', true)
        # now delete the selected entities
        defstogo.each{|d| d.entities.clear! }
        # now delete the unneeded materials
        matstogo.each{|m| model.materials.remove(m) }
        # commit
        model.commit_operation
        This will work in versions >= 8...
        • TNTDAVIDT Offline
          TNTDAVID
          **Hello TIG,
          Thank you for your very complete and precise example.
          I made a simple test on a component with the definition "BOX" which has a texture called "RED".
          The ruby dialog box returns "True", but does not delete the cube or the texture.
          http://i.imgur.com/ukvVTXi.gif
          Here is the code I copied and pasted into the dialog box:
            match = ['BOX']
            matstogo=['RED']
            defstogo.each{|d|
            d.entities.each{|e|
            matstogo.compact!
            matstogo.uniq!
            defsnottogo=model.definitions.find_all{|d| ! d.name =~ /#{match}/ }
            matsnottogo=['RED']
            defsnottogo.each{|d|
            matsnottogo << i.material unless matsnottogo.include?(i.material)
            d.entities.each{|e|
            matsnottogo << e.material unless matsnottogo.include?(e.material)
          ( matsnottogo << e.back_material unless matsnottogo.include?(e.material) ) if e.is_a?(Sketchup;;Face)
            matsnottogo.compact!
            matsnottogo.uniq!
            matstogo.delete(e) if matsnottogo.include?(e)
          Or is my mistake?
          Thank you in advance for your help.
          David**
            When I wrote match=/BOX/
            That is a regular expression.
            You wrote match=['BOX']
            That's an array containing a string...
            They are not the same thing !!
            So you need to try with a better set of variables !
            When I set a variable like matstogo=[] it's making an empty array to which we add elements...
            What made you think you need to diverge from my guidance ??
            • TNTDAVIDT Offline
              TNTDAVID
              **I used a array to "match" because there will be several different definitions to delete.
              As in your code you use:
              defstogo.each {| d |
              It seemed to me that "each" was used to browse a array.
              Your code works perfectly for a single definition, what if we have "CUBE", "TOTO" and "LOLA" to delete?
              For matstogo I did not know that it was possible to collect materials of a definition without naming them. I'm still surprised by the Ruby.
              Thank you for your help.
              David**
              • TNTDAVIDT Offline
                TNTDAVID
                **Hello Dan Rathbun and thank you for your help.
                @dan rathbun said:
                Then either you wrap what TIG showed you into a method, and call it 3 times from a loop:
                How to write the loop?
                I have done several tests and I still get this error message:
                Error; # <SyntaxError; <main>; syntax error, unexpected '|'
                For cname in ['CUBE', 'TOTO', 'LOLA'] do | cname |
                Then I tried your method by adding:
                Cnames = ['CUBE', 'TOTO', 'LOLA']
                The ruby console returns:
                purge_comps
                But nothing changes in SketchUp. 😲
                I have to move on from something obvious that I can not understand.
                Thank you in advance for your help.**
                • sdmitchS Offline
                  sdmitch
                  You are trying to define the variable "cname" twice in the same statement. delete the do | cname |
                  As usual Dan is right. You just need to wrap TIG's code with
                  ["cube","toto","lola"].each{|name|
                    match = /#{name}/i
                  http://sdmitch.blogspot.com/
                  • Dan RathbunD Offline
                    Dan Rathbun
                    MY BAD! I had a bad example (above.) [ Commented out that " do | cname |" part ]
                    >   match = /#{name}/i
                    That will actually create a separate undo operation for each entity (and it's materials) and will be much slower.
                    I gave you a complete working method at the bottom of that previous post !!!!!!
                    https://forums.sketchup.com/t/ruby-learning-resources-wikilists/22861
                    Get the old "Pick Axe" book and read it.
                    I'm not here much anymore.
                      Dan Rathbun
                      TIG is showing you how to purge ONEdefinition and it's materials.
                      @tntdavid said:
                      Your code works perfectly for a single definition, ...
                      No it does not. because you made 3 edits that make it NOT work properly.
                      CORRECTION: Actually I found 4 errors that made it not delete all the components or materials.
                      The second use of the Regexp was ! d.name =~ /#{name}/ (the regexp var is match.)
                      matsNOTtogo=[] was defined as matsNOYtogo=[], resulting in NameError
                      The comparison of back_material was conditional upon inclusion of front material in two statements.
                      @tntdavid said:
                      ... what if we have "CUBE", "TOTO" and "LOLA" to delete?
                      First, learn how and why TIG's code works for ONE definition, then learn how to modify it for multiple definitions.
                      for cname in ['CUBE','TOTO','LOLA'] # WHOOPS this not needed --> do |cname|
                        purge_comp(cname)
                      ... or you build a multi-match regular expression ( Regexp😞
                      cnames = ['CUBE','TOTO','LOLA'] match = /#{cnames.join('|')}/
                      Test file (SU2016):
                      CubeLolaToto.skp
                      "Color B04" and "Color J08" are unused.
                      "Color K03", "Color M06" are used by primitive faces.
                      "Material 2" is the leader color.
                      So here is a method with extra quirks:
                      • Returns false if array of cnames is empty.
                      • Short circuits and returns 0 if no definitions are found to delete.
                      • Reports both to console and message box number of definitions and materials purged.
                      • Returns number of definitions deleted.
                      # To test;
                      # purge_comps('CUBE','TOTO','LOLA')
                      # ... or;
                      # del = ['CUBE','TOTO','LOLA']
                      # purge_comps(del)
                      def purge_comps(*cnames)
                        return false if cnames.empty?
                        cnames.flatten!
                        return 0 if defstogo.empty?
                        matstogo=[]
                        defstogo.each{|d|
                          d.entities.each{|e|
                            ( matstogo << e.back_material unless matstogo.include?(e.back_material) ) if e.is_a?(Sketchup;;Face)
                        matstogo.compact!
                        matstogo.uniq!
                        matsNOTtogo=[]
                          d.entities.each{|e|
                            ( matsNOTtogo << e.back_material unless matsNOTtogo.include?(e.back_material) ) if e.is_a?(Sketchup;;Face)
                        matsNOTtogo.uniq!
                        defsgone = defstogo.size
                        matsgone = matstogo.size
                        # start and operation to ensure Garbage Collection works...
                        # clear the arrays of references to deleted objects;
                        matstogo.clear
                        defstogo.clear
                        # commit
                        msg = "#{defsgone} definitions purged\n#{matsgone} materials purged"
                        puts msg
                        UI.messagebox(msg,MB_OK)
                        return defsgone
                      If you absolutely must, you can call GC.start to ensure Ruby garbage collection runs.
                      • TNTDAVIDT Offline
                        TNTDAVID
                        CODE: SELECT ALL
                          match = /#{name}/i
                        Great thanks sdmitch,
                        You allowed me to understand what Dan Rathbun was explaining to me.
                        @dan rathbun said:
                        https://forums.sketchup.com/t/ruby-lear ... ists/22861
                        Thanks for the Dan link, I will follow your advice.
                        Here is the TIG method, which works for several definitions:
                        http://i.imgur.com/UwLix09.gif
                          match = /#{name}/i
                          matstogo=[]
                          defstogo.each{|d|
                          d.entities.each{|e|
                          matstogo.compact!
                          matstogo.uniq!
                          matsnottogo=[]
                          d.entities.each{|e|
                          matsnottogo.uniq!
                        With your help I reach my goals and I discover more and more the Ruby. 😉
                        Thank you all for your help.
                          Dan Rathbun
                          Your implementation still has a few errors.
                          David, I say again, that I gave you the code for a complete corrected method above.
                          It defines a method name purge_comps(*cnames)
                          • TNTDAVIDT Offline
                            TNTDAVID
                            **Sorry Dan, but I can not seem to make your method work.
                            In your method, how to integrate "CUBE", "TOTO" and "LOLA"?
                            David**
                            • TNTDAVIDT Offline
                              TNTDAVID
                              **Sorry Dan, I had not paid attention to your instructions in the code:
                              @dan rathbun said:
                              To test:
                              ... or:
                              purge_comps(del)
                              Your method works very well and offers new benefits. 👍
                              I noticed a small problem:
                              How to avoid deleting the texture of 'CUBE', if it is used elsewhere in SketchUp?
                              Thanks in advance for your help.**
                                Dan Rathbun
                                It is TIG's method with a few extra "bells and whistles".
                                I'll look at it today a bit and see if there is an issue.
                                EDIT: Okay, YES I see the issue. The method does not check the model level entities collection for used materials (on primitive entity objects.)
                                  Dan Rathbun
                                  # To test;
                                  # ... or;
                                  # purge_comps(del)
                                  # ver; 2.0
                                    cnames.flatten!
                                    matstogo=[]
                                    defstogo.each{|d|
                                      d.entities.each{|e|
                                    matstogo.compact!
                                    matstogo.uniq!
                                    matsNOTtogo=[]
                                      d.entities.each{|e|
                                    # now used by model entities
                                    model.entities.each{|e|
                                    matsNOTtogo.uniq!
                                    matstogo.clear
                                    defstogo.clear
                                    # commit
                                    puts msg
                                    return defsgone
                                  • TNTDAVIDT Offline
                                    TNTDAVID
                                    **Thanks for your reactivity Dan.
                                    Your solution works in the most by cases, but not all the time.
                                    The texture applied to TOTO should not be removed because it is used by the 4 Rectangle to Left:
                                    http://i.imgur.com/ywPqHyg.gif
                                    This mistake this product on my Click-Cuisine 2 furniture, and therefore makes the method unusable.
                                    Here's the SKP file:
                                    CubeLolaToto2.skp
                                    If you test your code on other examples the problem will not exist! 😮
                                    For this reason the problem is strange and requires an investigation.
                                    David**
                                      Dan Rathbun
                                      I agree. Sounds like a good learning experience for you.
                                      I'll let you do the investigation, and fix it.
                                      I've given you enough help for now.
                                      Your turn to do some of the work. 😉
                                      • TNTDAVIDT Offline
                                        TNTDAVID
                                        **Hello,
                                        You are right Dan, for the moment I still have not found a solution.
                                        I'm stubborn and I'd end up finding it!
                                        Thanks for your example Dirven ☀
                                        I have tested your code and the components are all removed from the SketchUp scene but nothing is purged.
                                        Is this normal?
                                        Edite:
                                        The Ruby console returns this message when I trigger your method.
                                        Error; #<NameError; undefined local variable or method `i' for Teste;Module>
                                        C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;60;in `block in purge_comps_n_mats'
                                        C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;56;in `each'
                                        C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;56;in `purge_comps_n_mats'
                                        C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;75;in `purge_comps'
                                        C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;85;in `block in singleton class'
                                        SketchUp;1;in `call'
                                        Thank you**
                                          driven
                                          edited my example...
                                          line 55 i is now item...
                                          john
                                            driven
                                            another way is to Hash the materials and set values for each...
                                              def purge_comps_n_mats(*args)
                                              model  = Sketchup.active_model
                                              defs   = model.definitions
                                              sel    = model.selection
                                              view   = model.active_view
                                              ents   = model.active_entities
                                              mats   = model.materials
                                              # add a hasj for materials and entities
                                              mats_h = Hash[mats.zip([1] * mats.size)]
                                              # this means you don't have to get Regexp right yourself
                                              names = Regexp.union(args)
                                              # this is similar to defs.to_a.dup.flatten
                                              list = defs.find_all { |d| d }
                                              # we will still only use one operation as v17 will error
                                              model.start_operation('mats')
                                              list.each do |defn|
                                                defn.instances.each do |i|
                                                   # optional 'showtime' for testing
                                            	sel.add(i)
                                            	view.refresh
                                            	sleep 0.2
                                                  dents = defn.entities
                                                  if defn.name =~ names
                                                    # get rid of the comps checking their materials
                                                     mats_h[defn.material] = 3 unless defn.material.nil?
                                                     mats_h[i.material] = 3 unless i.material.nil?
                                                     dents.to_a.each do |item|
                                                      mats_h[item.material] = 3 if item.respond_to? ;material
                                                      mats_h[item.back_material] = 3 if item.respond_to? ;back_material
                                            	# delete the instance
                                            	ents.erase_entities(i)
                                                  else
                                                    mats_h[defn.material] = 2 unless defn.material.nil?
                                                    mats_h[i.material] = 2 unless i.material.nil?
                                                      mats_h[item.material] = 2 if item.respond_to? ;material
                                                      mats_h[item.back_material] = 2 if item.respond_to? ;back_material
                                            		sel.add(item)
                                            		view.refresh
                                            		sleep 0.2
                                               mats_h.each { |k, v| mats.remove(k) unless k.nil? || v != 3 }
                                              model.commit_operation #
                                            purge_comps_n_mats('CUBE', 'TOTO', 'LOLA')
                                            john
                                            • 1 / 2
