    Blend Objects
    6 Posts 4 Posters 1.4k Views 4 Watching
      djh
      Can one "blend" objects in a manner similar to CorelDraw (or Illustrator [I'm sorry, I don't know the term to use in SU.])?
      If one ctrl key an object, moves it to a different position, and /#. It repeats the duplication # times. Is it possible to rotate the copied object and in between rotate all of the in between objects until they reach the copied object?
      • Rich O BrienR Online
        No, would be the short answer if you relied solely on SketchUp.
        But if you use TIG's Grow extension you can do it.
        Click to play...
        ...the pick point on the original object needs to be considered
        • filibisF Offline
          filibis
          Check this plugin: Component Stinger
            Maybe also something like a "morphing" thing?
            A cube becomes a pyramid in a number of step wanted!
            (rotate included at some places if wished too with a twisted curve) ๐Ÿ˜‰
            Or this ? ๐Ÿ˜„ (with 2D +Path by Kirill2008 )
            https://sketchucation.com/forums/download/file.php?id=39169
              djh
              pilou, thanks for responding. I saw the instructions that you attached. I selected all, right clicked, and ... nothing happened.If I right click, shouldn't there be some kind of option to morphing?
                Sorry seems this pluging not more updated! ๐Ÿ˜ฒ
                Seems it's works not entierely with the new version of SketchUp! ๐Ÿ˜ฎ
                So take Curviloft by Fredo ! Many options are inside! ๐Ÿค“
                Another little thing : for put face's object perpendicular to a curve use the tricky Pependicular face tool by Chris Fullmer
                Here between a Circle and a Rectangle by an Arc Circle
