    Splitting a sphere
    4 Posts 4 Posters 725 Views 4 Watching
    • KathrynGK
      KathrynG
      Short question please. How to I select the individual squares in this dome, or in a sphere so that I can delete those that I do not want? Not having much luck.
      Thank you
      "With SketchUp - Rome could have been built in a day!"
        Menu Display / Hidden Geometry
        • tuna1957T
          tuna1957
          Kathryn , What Pilou said. One extra tip is set your camera to Parallel Projection and Standard View to Front. You'll have better control on what you select, less likely to have an oops moment.
          • TIGT
            You also need View > Hidden Geometry ON so that you can see the 'smoothed' lines and the individual facets forming the surface are shown, and thereby also made selectable separately...
