    Reversed Selection Behavior
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    4 Posts 2 Posters 8.6k Views 2 Watching
    • plot-parisP Offline
      plot-paris
      Hi Thomthom,
      when modelling a sofa with your superb plugin I came across a peculiar behavior, that seems to occur with any geometry generated with SUbD, whether it is a live SUbD object or a plain mesh generated from it...
      Surely you are familiar with the excellent trick of SketchUp, where the direction in which you draw a selection frame influences what is being selected.
      • When you draw from left to right, only geometry completely enclosed by the selection frame is being highlighted
      • When you draw from right to left, all geometry touched by the selection frame is being highlighted.
      Now, with a SUbD mesh, selectin in such a manner does work. If however you press SHIFT / CTRL or both to add or subtract from a selection, this behavior is reversed (or behaves in another, unpredictable manner). Can you reproduce this?
      To make things easier, I have attached a file with a SUbD mesh on the left and an ordinary object on the right. Here you can easily see the difference when selecting using the modifier keys.
      This is not a big issue, of course. But interesting nontheless πŸ˜‰
      Incorrect Selection.skp
        When you have a subdivided mesh and you perform selections SUbD will try to expand the selection of the sub-entities to match the original control-entities.
        Unfortunately the API was lacking some feature to implement this to match SU's original behaviour. However, recently I think this has become possible. I have an issue logged to improve the box-selections.
          plot-paris
          Ah, I see. That does make sense.
          However, this behavior seems to stay with the geometry, even if you convert it to a plain mesh and explode the group. Could you find a way to undo this on conversion?
            Hmm... that is strange, if you convert to plain mesh SUbD should not be interfering...
            Can you show a video/gif of what you observe? Maybe we are talking about different things?
