    Use of Mac "command" key for shorcuts
    9 Posts 5 Posters 1.9k Views 5 Watching
    • pbacotP
      SketchUp will not let me use the command key when I am setting up shortcuts. What's the deal there. Is there a workaround, as script to fool it? It's been a bothering me because I use similar commands in another program and I always end up getting an error.
        I think that's not unusual. Certainly any keyboard shortcuts that are hard coded in the OS are going to be off limits. Cmd-C, Cmn-V, cmd-x for example. The same sort of thing happens on Windows. The OS will over ride the shortcuts.
        • S
          slbaumgartner
          Dave is exactly on the money. Keychords involving command never make it to the part of the app that handles user-defined shortcuts. They are either processed by OS X itself (which has many cmd-key shortcuts) or by the compiled-in menu system of the application. SketchUp doesn't allow them because they wouldn't work anyway!
          • pbacotP
            I think it's command-M then, specifically that I want to use. I set it in other programs and it's not blocked.
              Since custom CMD chords aren't allowed by SketchUp, could you use Shift instead?
              • pbacotP
                I have used another setup but it's mirror command like I've use in CAD for years and I wish it were the same or at least I could disable the apple command (minimize), because I can't help hitting this combination.
                • Louis GordonL
                  Louis Gordon
                  I don't think so. As @Dave R, Cmd-C, Cmn-V, cmd-x for example. I think that it's usual
                  • wind-borneW
                    wind-borne
                    Don't know if it's changed with time as I am on archaic 8 but I tested changing command M to delete easy enough in System Preferences and shortcut works.
                    "To read between the lines was easier than to follow the text."OSX 10.11.6
                    %(#BF80BF)[SU 8 pro
                    • pbacotP
                      Hahahaha GREAT! I didn't know about that wind-borne. Thanks a bunch! That overrides the Apple command. Life's little puzzles solved by Sketchucation.
