    Creating a plaid on a chair - cloth simulator?
    76 Posts 19 Posters 20.2k Views 19 Watching
    • J
      Jorgensen
      hi
      i wonder if anyone knows of a standalone cloth simulator?
      i would like to create a plaid that lays over a chair, like the one in the attached image.
      i have tried using artisan, but i'm finding it quite hard (but maybe not impossible) to create something similar.
      therefore, does anyone now of a plugin that can simulate cloth in sketchup, or some kind of standalone simulator that imports obj files (the chair) and exports obj files?
      any input is very welcome ๐Ÿ˜„
      jorgensen
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
        Drape CPoints by TIG can maybe help you!
        • J
          Jorgensen
          hi pilou
          thanks - drape cpoints looks very interesting. i will test that out.
          thanks
          jorgensen
          • F
            faust07
            Maybe you can also use SketchyPhysics for it. Possibly there is this technique once for MSPhysics. This example is made with models from 3D-Warehouse and the plugin "SketchyPhysics" (only up to SketchUp 2016, 32 bit).
              Cool!
              • J
                Jorgensen
                hi faust
                that is so cool - i have tried to install MSPhysics in sketchup 2017, and it seems to run - do i need more than that?
                thanks
                jorgensen
                • J
                  Jorgensen
                  and how the ..... have you made that fantastic cloth? ๐Ÿ˜„
                  i don't see that as a material type...
                  • HornOxxH
                    HornOxx
                    @faust07 said:
                    Maybe you can also use SketchyPhysics for it...
                    ๐Ÿ˜ฎ WOW !!!
                    never trust a skinny cook
                    • soloS
                      solo
                      What trickery have we here? ๐Ÿ’š
                      So damned cool.
                      http://www.solos-art.com
                      • C
                        cuttingedge
                        (sketchy Physics) didnt know that it has that capability at all .they've been sitting on my toolbar for a long while....
                          You must have also AMS Library!
                          • J
                            Jorgensen
                            Ok. Have that.
                            I was just surprised that it works in sketchup 2017 / 64 bit.
                            Jorgensen
                            • F
                              faust07
                              As I wrote, this runs only with "SketchyPysics" up to the SketchUp version 2016 32 bit. It still does not work with "MSPhysics" (SketchUp 2017, 64 bit). But the author of the plugin (Anton S) has something similar on his ToDoList.
                              The assignment of material is only possible after reaching the intended position of the cloth and storing a copy of the model during the pausing simulation.
                              • F
                                faust07
                                and here is the model, if you want to play...
                                The mesh count of the cloth can be increased by copying the elements accordingly and adjusting the numbering of the matrix ...
                                Two very interesting techniques have been used: self-linking groups and the creation of a surface following the simulation.
                                The model is a little bit modified by me (sorry, don't know the name of the author and can't find it on 3D-warehouse, only copies...)
                                If this could be translated for MS Physics one day - Hallelujah โ˜€
                                Cloth wth smooth faces_modAT_3.skp
                                • A
                                  Anton_S
                                  Actually this can be done with MSPhysics. All this does is creates a bunch of speres linked by BallAndSocket joints. Then it uses a script to move cloth vertices to new position. This is artificial cloth and has its downsides, primarily the performance. But I can modify that small script for compatibility with MSPhysics.
                                  • F
                                    faust07
                                    Ingenious, I've known it... Thanks, Anton! ๐Ÿ˜Ž
                                    • J
                                      Jorgensen
                                      So it might work with msphysics?
                                      I hope as I don't have access to su 2016 anymore.
                                      • C
                                        cuttingedge
                                        a proof of concept to creating like "Marvelous Designer " plugin perhaps. Are we still decades away from there?
                                        • A
                                          Anton_S
                                          Here is the proof!
                                          I intend of writing a new plugin for this kind of stuff.
                                          • J
                                            Jorgensen
                                            That would be very very cool Anton!
                                            It would make cloth creating a lot easier.
                                            Just create a flat cloth, add a nice texture, animate the cloth onto a chair, stop the animatin, make small adjustments with artisan or like - and render.
                                            Can we set the resolution of the cloth?
                                            Jorgensen
                                            • 1 / 4
